1950 JD 'B' ? granny gear?
   / 1950 JD 'B' ? granny gear? #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
1950 JD \'B\' ? granny gear?
I was just remember ing back a few months ago when i took delivery of my JD 'B'.. I remember the owner saying something.. like ' oh yeah.. this has a granny gear...
Now that I'm stating to play with it.. All I see is the powertroll lever, and the clutch lever, and the tranny shifter... am I missing a lever? ( I guess there may also pe a bto lever.. though i don't recall where it is? )
help....
Soundguy
   / 1950 JD 'B' ? granny gear? #2
Re: 1950 JD \'B\' ? granny gear?
No I think he's just referring to 1st gear being very short. There was, however, a sort of "overdrive" gear on some B's. I remember my Grandpa's B had another lever up by the throttle that was some sort of high/low trans. The lever connected to a vertical shaft that went down into the tranmission My Dad's B, on the other hand, has 6 speeds, but no high/low. Grandpa's B would move pretty quick down the road when the hi/lo was in "high". I really don't remember much about it other than my Dad commenting a time or two that the OD gear was too much speed for the tractor.
Yep.. mine has 6 gears too.. and is has quite a bit of 'pep' in 6 on the road. .. in fact I was afraid to use it till I serviced the wheel bearings / brakes / steering box.. wanted to be sur eat that speed that if I hit a pedal or turned the wheel.. that it actually would / could respond..
Soundguy
   / 1950 JD 'B' ? granny gear? #4
Biggest problem with high speeds on the old Deeres is there is no way to lock the brakes together for balanced braking - if you need to stop fast, don't even think about applying just one brake - unless you want to turn quickly (and possibly turn the tractor over, too). All part of the charm!
2020 PETERBILT 567 DAY CAB (A53426)
2020 PETERBILT 567...
2023 JOHN DEERE 3033R LOT IDENTIFIER 83 (A53084)
2023 JOHN DEERE...
2017 Makita HM1307CB 35lb Demolition Hammer (A52377)
2017 Makita...
City of Buckhannon -Onan 50 Set Stand By Generator (A52384)
City of Buckhannon...
John Deere Gator Utility Cart (A50324)
John Deere Gator...
2017 John Deere Gator TS Utility Cart (A50324)
2017 John Deere...
