1949 Ford 8N detergent vs non-detergent oil
   / 1949 Ford 8N detergent vs non-detergent oil #1
scrimmi1
John Deere 950
I'm changing the oil in a 1949 Ford 8N. The existing oil was very dirty and there was sludge in the bottom of the oil drain plug/screen and oil filter housing. The existing oil type in the tractor is unknown. Should I switch to a modern detergent type 15W40 or use a 30W non-detergent oil to avoid breaking down the sludge further and causing possible engine damage?
   / 1949 Ford 8N detergent vs non-detergent oil #3
I would put detergent oil in it and change it very frequently for 2 or 3 changes to flush the sludge out.
   / 1949 Ford 8N detergent vs non-detergent oil #4
Conventional 10W30 oil and filter change.
Tractor will last your lifetime.
   / 1949 Ford 8N detergent vs non-detergent oil #5
conventional detergent oil and if you desired to change just the filter after 10-20 hours.
   / 1949 Ford 8N detergent vs non-detergent oil #6
So, . . . You would do the same with an original 1950's Massey Harris 44 Special gas? Continental 4 banger.
The old gentleman I bought it from almost made me promise to ALWAYS run straight 30.
Maybe gets 10 hrs a year, NOW switch it over to a 10/30 diesel oil??
I'm nervous.
   / 1949 Ford 8N detergent vs non-detergent oil #7
It's your tractor use whatever oil you want, if were me it would be a detergent oil. It will not hurt a thing to change.
   / 1949 Ford 8N detergent vs non-detergent oil #8
I have a old ford 851 with a rear main seal leak. The only oil it gets is the drained oil out of my other vehicles and it really dosnt care.
   / 1949 Ford 8N detergent vs non-detergent oil #10
I'm nervous.
I would. You should be more nervous about getting hit by an asteroid.
(4) 3 PLUG VALVES (A52472)
(4) 3 PLUG VALVES...
Komatsu Midi Excavator (A51691)
Komatsu Midi...
New/Unused Fuel Pump with 50ft of Hose (A51573)
New/Unused Fuel...
2008 MAGNUM TRAILER LIGHT TOWER TRAILER (A52472)
2008 MAGNUM...
2008 CATERPILLAR 304C CR EXCAVATOR (A51406)
2008 CATERPILLAR...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
