Uh, visually check wire from key switch to coil. From the factory power hit a terminal on a resistor board, wire to the switch, wire from the switch to a ballast resistor, other side of the resistor to the coil. Some people add in extra ceramic resistors, or remove the ballast resistor and add in a ceramic resistor. Need to know what you have inline . Too much series resistance = weak or no spark, not enough leads to thermal breakdown and damage to the coil.
