1948 Case LA Propane powered
/ 1948 Case LA Propane powered #1
Big Red Case
Old Case
I got this tractor home a couple of months ago.
And not sure how to post pics on here yet. Maybe need a few posts first?
A couple of weeks ago I got it started. The numbers on the oil pressure gauge are worn off/sun faded. But the needle moved so I figured that's a good start. After an hour of flushing the radiator I got it to sorta run clear water through it. Then I drove one lap around my yard.
Now that I've tested it I am going to start working on it to my goal of moving dirt. I also got a box scraper with it but the tractor has no 3 pt hitch. From reading it was built before 3pt hitches were standardized on equipment. It also has a hydraulic pump on the pto.
First things first what would be a proper oil for this? Straight 30 wt or 10w30?
I am also going to replace the oil pressure gauge so I can see what it does.
And should I add any kind of additives to the oil?
If so what kind?
JOHN DEERE 7330 TRACTOR (A64276)
JOHN DEERE 7330...
2017 Mercury SeaPro 115HP Outboard Boat Motor (A61574)
2017 Mercury...
2010 Sterling A9500 T/A Day Cab Truck Tractor (A61568)
2010 Sterling...
2025 Kubota L3902HST w/ Kubota LA526 loader - 1 hour and new financing
2025 Kubota...
2018 Infiniti Q60 AWD Coupe (A61574)
2018 Infiniti Q60...
Mini Skid Steer Mount Plate, 5/16" Thickness (A62679)
Mini Skid Steer...
