1939 Farmall A
   / 1939 Farmall A #1
Bungiex88
Dysart
73 Farmall 574, 2016 mahindra 1533
I have a 1939 a and was wondering what the original configuration is as far as electrical. There is no battery or starter. I dont even think theres a cover were an optional starter goes. Can anyone tell me if a 1939 came from factory with a starting system or not. Id like to restore this tractor but i dont know anything about it. Just trying to make sure as far as distributor cap should be on this tractor and does it have a generatir or magneto i have no idea. I bought a manual for it but its a general manual for all the a痴.
   / 1939 Farmall A #2
I had a quick look on tractordata.com and they said that both engine versions (gasoline/petrol or kerosene) had an optional electric start.
Electrical ground is positive.
   / 1939 Farmall A #3
if there is no battery, it isn't battery ignition. ;) It should then have a magneto. if it has a magneto, it may or may not have a starter.
So you might have a hand crank model with a magneto.
   / 1939 Farmall A #4
1939 was the first year of the IH styled tractors. As mentioned, starters were an option. I had a '39 B. Pretty bare bones model, There was no hole in the torque tube for a starter on mine. Just a hand crank, with mag.
   / 1939 Farmall A #5
I have a 1939 a and was wondering what the original configuration is as far as electrical. There is no battery or starter. I dont even think theres a cover were an optional starter goes. Can anyone tell me if a 1939 came from factory with a starting system or not. Id like to restore this tractor but i dont know anything about it. Just trying to make sure as far as distributor cap should be on this tractor and does it have a generatir or magneto i have no idea. I bought a manual for it but its a general manual for all the aç—´.
WOW! that would be a antique tractor show hit I expect. The one I entered with our 1966 Ford 3000 with the one arm loader had many old Farmalls but I think all were rubber tired.
   / 1939 Farmall A #6
They made a lot of A's and most ALL of the early tractors lacked electric start, like was already said, it was optional...
My A does have electric start, but I have other models that don't, and it does start pretty easy with the crank.
When you go to a show around here, a manual start model isn't uncommon at all...
SR
   / 1939 Farmall A #7
I had so much with the 6 volt system on my WD there were months when I used the hand crank more than the starter.
   / 1939 Farmall A #8
my c had a starter and a battery ignition. when I bought it the starter was packed with mud and bad. I ran cables from my truck tot he ignition coil and hand cranked it setting out in the field.. had no oil pressure gauge but I always carry one with me hooked to a grease gun hose. had oil pressure but crank seal was gone on timing cover so puked oil fast, but ran, so I brought it home.
Tennant S30 Ride-On Industrial Floor Sweeper (A51691)
Tennant S30...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
2010 LONE STAR TRAILER MFG. GOOSENECK TRAILER (A53843)
2010 LONE STAR...
2018 Infiniti QX60 AWD SUV (A51694)
2018 Infiniti QX60...
2001 John Deere M665 (A50120)
2001 John Deere...
2025 Safety Basket Forklift Attachment (A51691)
2025 Safety Basket...
