Verticaltrx
Veteran Member
- Joined
- Dec 30, 2009
- Messages
- 1,908
- Location
- VA
- Tractor
- Kubota B3200/L2501/SVL65-2/U35-4, IH 454/656, Ford NAA, Case 1845C/480E/450C LGP
I'm getting ready to do a complete rewire on our 'new' home and had a few questions for some of the more electrical savvy folks on here. I'll start by saying that I am a General Contractor and have a decent bit of electrical experience, but it's been years since I've done a re-wire so I'm sure a lot has changed since then.
Little info on the house: 2000sf 1.5 story, built in late 1920's. Wiring has been 'added' through the years with the oldest being the old fabric covered romex, newest looks to be 15-20yrs old. Some of the wiring terrifies me, I shut the main off whenever I'm not there. A majority of the connections are not in boxes and consist of two wire twisted together with electrical tape (no wire nuts). I could go on and on with the electrical horror's I've found. Anyways, the house has one bathroom and oil and wood heat. No AC unit and no plans for one. Has an electric range and electric hot water. So not a huge amount of electrical load and don't have plans for any more.
With that said, the house only has a 100amp service coming in now. It has a almost new 100 amp breaker box, which I wouldn't mind re-using, but I'm not sure if 100 amps is enough. I guess my first question is should I upgrade to 200 amp service at this point?
Second, shared neutral circuits. I'm a fan of them since it really allows you to clean up the wiring, but I've also heard of some drawbacks. What's the story on these nowadays?
What's the best way to group devices together on a given circuit? My feeling is put lights on one for a given area and outlets on another. How many rooms is it ok to group the lights together in? How many outlets? Is is still okay to use one GFCI circuit for both the kitchen and bath?
Lastly, what is the best way to cut in new boxes into plaster walls? There are a couple places I'd like to add outlets, but don't want to make a mess out of the walls. Other options for outlets besides going in the walls?
I'm sure I'll have more questions as I get into the project but those are the first that come to mind. Thanks in advance. :thumbsup:
