1920 ROPS Questions - Is mine modified? / Can it be repaired?
   / 1920 ROPS Questions - Is mine modified? / Can it be repaired? #1
mroberts5
Bucks County, PA
Ford/NH 1920
I had asked questions about the modification of the ROPS and if the crack can be repaired, but I answered my own question.... I'll be replacing it.
   / 1920 ROPS Questions - Is mine modified? / Can it be repaired? #2
I have never seen rops mounted on the fenders. Can`t be that strong.
Its mounted to the axle - the fender is mounted to the axle as well, through the rops mount.
It's the split in the rops that is the mod.
   / 1920 ROPS Questions - Is mine modified? / Can it be repaired? #4
The ROPS mount as shown is normal for a 1920.
Those SPLITS in the ROPS are nasty! (looks like new mounting bolts though)
A ROPS replacement is definitely required!
Dunno. But that buldging isn't normal? Standard is straight?
   / 1920 ROPS Questions - Is mine modified? / Can it be repaired? #8
It will be cheaper for someone to make one for you. Most junk yards will not sell the ROPS. I would replace that one.
202482 (A54757)
202482 (A54757)
Quick Attach Bale Spear (A57454)
Quick Attach Bale...
2018 Toro Workman MDX Utility Cart (A56857)
2018 Toro Workman...
Atlas Copco XAS90JD Portable Air Compressor (A57453)
Atlas Copco...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
Toro Sand Pro (A56859)
