1910 Voltage Regulator
   / 1910 Voltage Regulator
I ended up replacing the VR and it didn't change the readings. One thing that I did was tighten the alternator belt really tight. That seemed to help alot. It's possible that a new belt might even give me better results. As is, the light is still flashing on the dash at very low RPM's (less the 1k). If revved up, the light goes out. I don't use the tractor that much, and honestly, it just one of those things that I've learned to ignore and live with.
I would get a buddy and really tighten up the belt and see if that helps. Sorry this wasn't much help.
Good luck.
   / 1910 Voltage Regulator #13
You've blown one of the diodes only get half the amps that is why the gen lite comes on. Rebuild alt or buy a rebuilt
   / 1910 Voltage Regulator #14
Good luck.
Did you get a mechanical or solid state VR? Do you remember the brand if it was mechanical?
2015 Kubota KX91-3S2 Mini Excavator (A55973)
2015 Kubota...
2014 Dodge Ram 4500 Versalift Bucket Truck (A55973)
2014 Dodge Ram...
2020 Chevrolet Tahoe SUV (A55973)
2020 Chevrolet...
John Deere 1025R (A53317)
John Deere 1025R...
2012 International Derrick Digger (A55973)
2012 International...
international water truck (A55973)
international...
