1910 Voltage Regulator
   / 1910 Voltage Regulator
I ended up replacing the VR and it didn't change the readings. One thing that I did was tighten the alternator belt really tight. That seemed to help alot. It's possible that a new belt might even give me better results. As is, the light is still flashing on the dash at very low RPM's (less the 1k). If revved up, the light goes out. I don't use the tractor that much, and honestly, it just one of those things that I've learned to ignore and live with.
I would get a buddy and really tighten up the belt and see if that helps. Sorry this wasn't much help.
Good luck.
   / 1910 Voltage Regulator #13
You've blown one of the diodes only get half the amps that is why the gen lite comes on. Rebuild alt or buy a rebuilt
   / 1910 Voltage Regulator #14
Good luck.
Did you get a mechanical or solid state VR? Do you remember the brand if it was mechanical?
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A55973)
2023 HarbinGer V3...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
2019 TerraGator 7300 Spinner truck (A55315)
2019 TerraGator...
2012 International Prostar (A56435)
2012 International...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A56859)
2004 Fleetwood...
