1910 Short Circuit
   / 1910 Short Circuit #11
In all your posting, you have not mentioned if you have a voltmeter. You said you tested the fuses, but didn't describe the method. Anyhow, if the fuse is good, you should have power on the output side. If you have power there, then check the light switch for power coming to it (turned off). Then turn the switch on and check for power leaving the switch. My guess is that you'll either find the fuse was mis-diagnosed as good or the light switch is toasted.
   / 1910 Short Circuit #12
Am I missing something? Glow plug circuit has not been in the discussion.
The key switch controls the glowplugs; the glowplug load is carried by the fusible link and ignition switch. Whether discussed or not, a fault in the glowplug circuit could be the cause of the problems. As yet, the OP hasn't explained how any of the troubleshooting has been done, or whether he has and knows how to use a VOM or even a test lamp. Corroded fuseholders are common on old tractors, too.
2005 CATERPILLAR 262B SKID STEER (A52709)
2005 CATERPILLAR...
2007 Freightliner (A57148)
2007 Freightliner...
HUSKEE 35TON 12.5HP LOG SPLITTER (A58375)
HUSKEE 35TON...
2024 KUBOTA SVL75-3 SKID STEER (A52709)
2024 KUBOTA...
1995 Advance Mixer CM3A6811 11 Yard Tri-Axle Concrete Mixer Truck (A56858)
1995 Advance Mixer...
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
