1900 FEL Plumbing........
/ 1900 FEL Plumbing........ #1
Anonymous Poster
Epic Contributor
I have an '82 Ford 1900 4wd and just had a Westendorf front end loader installed. Love the loader but with the hyd hoses attached, my 3ph doesn't operate. Do I need to install some sort of pass-thru hose at the control or ball valve shut off in the pressure hose for each to work without disconnecting hoses each time? Thanks for any thoughts.
/ 1900 FEL Plumbing........ #2
Fitz, I have a 1910 with a factory FEL. Look on the right side rail were the bell casting tapers into the transmission ( in front of the brake pedals) and you'll see the "Combination System Relief-Diverter Valve Manifold Assembly". It's a square block about 3-4" with 2 Allen headed plugs(these are auxillery ports and may be in use on your configuration) and between them and a little lower is a slotted bolt head. It takes a pretty hefty screw driver and you don't want to wallow out the slot . Turn this 90 degrees ( if its at 2 o'clock go to 10 o'clock or visa versa). RCH
2022 CATERPILLAR 289D3 SKID STEER (A64279)
2022 CATERPILLAR...
5.5x13 Homemade Trailer (A62613)
5.5x13 Homemade...
PT 1000 Gallon Supply Tank (A57149)
PT 1000 Gallon...
Jack Daniels Mini Decorative Truck (A61574)
Jack Daniels Mini...
2003 MAC TRAILERS 45' WALKING BOTTOM TRAILER (A60430)
2003 MAC TRAILERS...
2006 Ford F-150 Ext Cab Pickup Truck (A61573)
2006 Ford F-150...
