1900 3 POINT HITCH WON'T RAISE
   / 1900 3 POINT HITCH WON'T RAISE #21
ok i did pull spool apart, not to worry I teach machining and fabrication and repair all my own equipment,lathes , milling machines , power shears....but this is kicking my butt!!!! ok worry !! it all came apart as it should except the slotted port #21 check valve seat, it is TIGHT!!! , Will make a tool to fit slot better and get it out, everything else is clean and free ,all o rings looked good,
Okay, why don't you take close up pics of the block and ports so will have it for future reference. 3 bolts that attaches the relief to lift cover are long due to hyd block width. As Jim suggested if you temporarily take out the block then you can check your spool and lift system now that we know you have flow up to that point. I wonder if you have shorter bolts or can put enough shims/washers to make it work.
JC,
Its going back together , GREAT IDEA !! I will assemble without loader in the system ,then if that does not let 3 pt work ,I will make tool to get check valve out of spool!!! I have nothing but time this weekend , THANKS AGAIN
WE HAVE LIFT !!!!!!!!!! Removed loader block and works great!!! now what???
I did take spool apart and put it back together before removing block,don't think i fixed anything ??? I will check block with light , air!!! but this is progress, :)
   / 1900 3 POINT HITCH WON'T RAISE #25
woo hoo, :thumbsup:slowly but surely.. we reached the top:cool::cool:. That shows your lift spool works, shock relief works like it should and piston seal is working at least as of now. Got to check that check valve on the hyd block. The guilty part is found.
JC:):)
blew out block ,put back together 100%, and everything works???don't know what did it but we did it !!!! 3 pt picked me up 200lbs and loader has 200lbs in it. just took all back apart to rtv seal for spool cover and put new o rings in the .outer block and pressure relief . THANK YOU !!!!!!WILL KEEP U POSTED TOMORROW WHEN IT GETS OUT!!
   / 1900 3 POINT HITCH WON'T RAISE #27
Great, there was a gremlin somewhere in the circuit that was evicted.:D when was the last time you had hyd fluid and filter change?
JC,
I just picked this up for my hunting camp /northern mi. get away /84 acres 1week ago today knowing the 3 pt did not work, but knew the loader worked good ,1 owner and never had anything hooked up in the rear to the 3 pt.. 2000 hrs. $2750.00 , I checked the filter - clean.the seller gave me the dealer papers he took it to before I bought it to have 3 pt fixed , hyd. oil change plus looking for 3 pt. problem $900 / it is in awesome shape.
Side note ... is this internet thing awesome !!!! talking to guys across the country who know and or had the problem before , helping , saving $$$
Thanks!!!!!!!!!! will give an up date tomorrow.
   / 1900 3 POINT HITCH WON'T RAISE #29
That's a great price and good tractor you got. These series Ford Tractors are real work horses, give them a bit TLC and they repay it all.:)
JC,
   / 1900 3 POINT HITCH WON'T RAISE #30
Wow! I went away long enough to watch my Rangers choke in the World Series and this morning I see you've fixed your tractor. YEA!!!! Way to go, Toolhawk!:thumbsup: My guess is that one of the internal o-ring seals was leaking and you replaced the seal or somehow stopped the leak. It's all good.:)
UNUSED FUTURE HWG72 72" HYD HOLLOW WOOD GRABBER (A58376)
UNUSED FUTURE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
400 Ton Cincinnati Press Brake (A59213)
400 Ton Cincinnati...
5' ROTARY MOWER (A58375)
5' ROTARY MOWER...
Mini Skid-Steer Stump Grinder (New/Unused) (A59225)
Mini Skid-Steer...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A56438)
2018 John Deere...
