19.5 Dually tires
   / 19.5 Dually tires #1
Tomtint
Elite Member
Boston
L3700SU
So I have a couple F450s with the 19.5s .. One of the trucks is a 2021 Limited diesel that I pull our 5th wheel camper with. Truck has about 22K miles on it and when I got back from Fla last spring The tires were shaking in the rear.. Went to a couple different shops.. One was a truck place and they balanced them but it still shook.. I bought centramatics.. Still shook.. Bought 6 new tires.. Still shakes.. The wheels are balanced with weights and centramatics in between the dually.. Maybe take off the lead weights ? ..Dont know if that's messing up the balance using 2 systems.. ? .. On the other F450.. Its a 2018 V10 4x4 dump truck.. Has about 15 k miles and a number of years ago I put Kelly tires it for traction in the snow.. They shake like crazy over 50MPH.. same centramatics, ..still basically underivable over 50MPH. Brought the truck to a tire guy and he says tires have flat spots..need 6 new tires... So do I do begs, wheel weights or try the centramatics .. ? This is getting aggravating and expensive...
   / 19.5 Dually tires #2
I have had the Kelly 19.5’s and the Goodyear 19.5’s. Basically the same tires, with no issues. No shaking like you describe.
Today, I am picking up a set of 6 Continental HD3’s.
I have a bit of a shake with my Kaufman trailer tires between 30-35, then it goes away. Could never figure out the reason. The bed kind of “hops” slightly between 30-35. Balanced all the tires and it did nothing.
   / 19.5 Dually tires #3
I put these on my F550.
Off shore tire, but good pricing and tread is kind of a Continental copy. Never had any issues with them. No balance or shakes, good winter traction and weared good.
  • Good Post
Reactions: D&D
   / 19.5 Dually tires #4
This may sound crazy but have you checked to see if you have one that is out of round? I ask because that is a problem I had several years ago.
   / 19.5 Dually tires #5
On the 2018, did they spin balance the old tires first?
On the 2021, if tires weren’t it, next I would look at is wheel bearings and brake rotors
   / 19.5 Dually tires
The 18 is at the tire shop now. That's the one that has the Kellys.. Tire guy said the first one he spun had a flat spot. .. But they all shake.. front and rear. Truck has 15k on it so i highly doubt it's a bearing anywhere. Those Kellys had beads, weights and now centramatics.. Never a good ride over 50mph.
   / 19.5 Dually tires
Yes they were spun first and had weights on them. The 21 is pampered.. No mechanical issues whatsoever.
   / 19.5 Dually tires #8
Have you had someone follow you taking a video? It might provide some insight, like wheel hop or wobble. Having the wheel weights with the centramatics doesn't matter. I have weights with mine, and when it through a weight, no change in ride!
   / 19.5 Dually tires #9
The only way you can check if a tire is out of round is having a machine that can test for this. An out of round tire will balance but you need the tire machine that will test specifycally for out of round
willy
   / 19.5 Dually tires #10
Ok
2008 TEXAS BRAGG GOOSENECK FLATBED (A58214)
2008 TEXAS BRAGG...
LOT: Fuel Transfer Tank, Tool Box, 12 Volt Fill-Rite Pump (A59076)
LOT: Fuel Transfer...
WHEELBARROW & TOOLS (A58374)
WHEELBARROW &...
2015 Ford Escape SUV (A56859)
2015 Ford Escape...
White Metal Roof Panels (A55758)
White Metal Roof...
New/Unused CFG Industrial H12R Mini Excavator (A57453)
New/Unused CFG...
