19-23 Parker Hydraulic Control Valve
   / 19-23 Parker Hydraulic Control Valve #1
surreynd58785
1952 Ford 8N
Good evening,
I have a 19-23 Dearborn loader to which I am having issues with the hydraulic control valve and was wondering if anybody knows where online I can download the manual for it. It is a Parker 8743 control valve. Also, if I want to replace it with a much newer valve, what is out there that I can use? Any and all assistance would be greatly appreciated. Take care and God Bless.
Paul
(701) 728-6824
   / 19-23 Parker Hydraulic Control Valve #2
Is your system an open center hyd system?
How many GPM's does the tractor hyd pump produce?
Good question and I do not have an answer for you at this time. It originally came with the loader I was told. Any way of finding this out by looking at the pump? Thanks for the reply and have a great week.
Paul
   / 19-23 Parker Hydraulic Control Valve #4
Paul
The tractor specs say you have this for your Ford 8N.
Pressure: 1700 psi
Pump flow: 2.85 GPM
Not a lot of pressure.
Have you considered a PTO hyd pump to power the loader. More pressure and GPM.
11.4 GPM @ 2,000 PSI & 18.1 Hp input
Surplus Center - 5.7 CU IN PRINCE HC-PTO-2A PTO PUMP 540 RPM
   / 19-23 Parker Hydraulic Control Valve #5
Good evening,
Paul
(701) 728-6824
If you need a new loader valve, take a look at this one.
Surplus Center - 2 SPOOL 10 GPM PRINCE LVT1GB5AC1-26 OC VALVE
2016 TRAILSTAR 40FT DUMP TRAILER (A54607)
2016 TRAILSTAR...
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A52748)
2012 Freightliner...
2018 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A52705)
2018 PRINOTH...
2012 SOUTHERN 130BBL VACUUM TRAILER (A53843)
2012 SOUTHERN...
2018 KENWORTH T880 (A53843)
2018 KENWORTH T880...
2006 Imperial 14Ft Flatbed T/A Equipment Trailer (A50324)
2006 Imperial 14Ft...
