19-23 Parker Hydraulic Control Valve
   / 19-23 Parker Hydraulic Control Valve #1
surreynd58785
1952 Ford 8N
Good evening,
I have a 19-23 Dearborn loader to which I am having issues with the hydraulic control valve and was wondering if anybody knows where online I can download the manual for it. It is a Parker 8743 control valve. Also, if I want to replace it with a much newer valve, what is out there that I can use? Any and all assistance would be greatly appreciated. Take care and God Bless.
Paul
(701) 728-6824
   / 19-23 Parker Hydraulic Control Valve #2
Is your system an open center hyd system?
How many GPM's does the tractor hyd pump produce?
Good question and I do not have an answer for you at this time. It originally came with the loader I was told. Any way of finding this out by looking at the pump? Thanks for the reply and have a great week.
Paul
   / 19-23 Parker Hydraulic Control Valve #4
Paul
The tractor specs say you have this for your Ford 8N.
Pressure: 1700 psi
Pump flow: 2.85 GPM
Not a lot of pressure.
Have you considered a PTO hyd pump to power the loader. More pressure and GPM.
11.4 GPM @ 2,000 PSI & 18.1 Hp input
Surplus Center - 5.7 CU IN PRINCE HC-PTO-2A PTO PUMP 540 RPM
   / 19-23 Parker Hydraulic Control Valve #5
Good evening,
Paul
(701) 728-6824
If you need a new loader valve, take a look at this one.
Surplus Center - 2 SPOOL 10 GPM PRINCE LVT1GB5AC1-26 OC VALVE
2021 ALLMAND BROS, INC. NIGHT LITE TOWER (A53843)
2021 ALLMAND BROS...
2021 International HV507 4x4 12ft Single Axle Dump Truck (A54814)
2021 International...
Sterling AT (A53473)
2015 Mitsubishi Outlander Sport SUV (A53424)
2015 Mitsubishi...
SCAN FOR HAULING AND FINANCING INFORMATION (A52706)
SCAN FOR HAULING...
