Mowing 1864 mower raise and lower lever is stuck
   / 1864 mower raise and lower lever is stuck #1
backporchguy
Murphy NC
Cub Cadet 1864
I have a Cub Cadet 1864 with a 48" mower. The lever for raising and lowering the mower is stuck. Is this likely a hydraulic pump issue or a mechanical problem? Any ideas on how to repair this? Also, I am planning to sell the tractor as soon as I resolve the mower issue. My wife and I are embarking on full-time RV living in a few months. My tractor has about 715 hours on it. Other then the mower problem, the tractor is in good condition. The Kohler engine runs like a champ. Is $1800 a fair asking price? Many thanks for your help.
   / 1864 mower raise and lower lever is stuck #2
Is the lever physically frozen, which would indicate a mechanical problem with the lever itself or the valve assembly, or does the lever move up and down but the deck doesn't move? The latter would indicate a hydraulic problem probably with the valve asm. I had a leaking valve asm. replaced and it was expensive to the tune of $600 (dealer replaced).
Bob B.
The lever is frozen. I'll pull the assembly out this weekend and see if I can discover a mechanical reason. Thanks.
3000 Gallon Black Poly Water Tank (A49461)
3000 Gallon Black...
2020 MACK PINNACLE (A50854)
2020 MACK PINNACLE...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
TRUCKING INFO (A50774)
Allis Chalmers Disk (A50515)
Allis Chalmers...
2018 CATERPILLAR 249D TRACKED SKID (A51222)
2018 CATERPILLAR...
