1850 Center Section rebuild results
   / 1850 Center Section rebuild results #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
Well, let me say first that I should learn to never trust terry ;-). He says, It takes a couple of hours, 2 floor jacks and a pry bar. I say it takes 8 hours, $100 in parts, my wife, my truck, and most of all my patience.
I think because it was the big 1850 that this job is a lot harder than a smaller 1430 or 425.
I guess that I could spend the whole page with a step by step process, how it may times I had to rehook up the steering cylinders, or had to get the pick up to pull it apart. How out of all the parts I bought I only used the snap rings and spacers (which is all that Terry said I needed to replace anyway). I have $90 worth of bearing, pin and nut now sitting on my shelf if someone needs it. Oh, you will need to clean the threads as I have damaged both the new nut and the bolt following the pound it back in advice I received. The new bolts are not made as well as the old bolts BTW.
Anyway. It is done, The tractor rides correctly. It was all about the spacers and how tight I kept everything.
   / 1850 Center Section rebuild results #2
sounds like a demonstration of a job that would be worth paying someone to do. It did sound pretty simple going into it.
Sort of like replacing the strut cartridges on a car... after I did that once when I was 19, and I swore that I would never do it again... it is well worth the money to get someone else who has all the right tools to do it for you.
   / 1850 Center Section rebuild results #3
woodlandfarms said:
He says, It takes a couple of hours, 2 floor jacks and a pry bar. I say it takes 8 hours ***
I never learned to estimate that kind of project in hours. How much is that in six-packs? :D
   / 1850 Center Section rebuild results #4
Carl,
Did you happen to take any pictures? I believe that only a couple of people have rebuilt the center section. I would like to see pictures or description of what you did. Did you get all the parts in a kit from PT?
If I drank I would have lost count of the 6 packs. There was the moment of taking the 1 13/16 wrench and beatling the canopy in front of my wife. That is when I would have upgraded to something harder if I could have found the kitchen
As for pictures. I swore I was going to, and the camera was there. But things went so south. I can take pics or the kit, and I think doing this with a smaller tractor (not muscling 8 wheels) and not having left the mower on (did not realize it until I had the steering unhooked).
The 2 big surprises was the bearing in the center was nothing more than a fancy verson of the swiveling ball ends on the end of our hydraulic rams. Also, the spacers ar about 1/3" of just cut pipe...
But, I can talk you through it if you ever have questions...
   / 1850 Center Section rebuild results #6
Carl,
It sounds like brute strength, with a big dose of not knowing what was needed.
Can you please write it up, while it is still fresh in your memory about what is involved? (Perhaps saving someone else a few 6 packs, that they might donate to you?)
Thanks!!
All the best,
Peter
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
UNUSED RAYTREE RMSC78 78" HYD SOIL CONDITIONER (A57193)
UNUSED RAYTREE...
UNUSED FUTURE X-HWG72-72" HYD WOOD GRABBER (A57193)
UNUSED FUTURE...
UNUSED JCT 2 PRONG BALE SPEAR (A57193)
UNUSED JCT 2 PRONG...
1608 (A57192)
1608 (A57192)
