1841 coming back to life
   / 1841 coming back to life #1
SnoC653
Iowa
Ford 1841 Industrial
Bought a property and an old 1841 with FEL came with it. It was parked outside and badly neglected but has potential.
The cable over hydraulic steering is missing all hardware from the reduction gear to the cylinder and the steering pump was filled with pink milkshake as someone put ATF in it.
Right rear wheel has a small hole oozing calcium chloride.
Pins in the loader are all wrong and fit poorly.
Should be fun.
   / 1841 coming back to life #2
Welcome to the Forum :welcome:
I love those pie wheel weights!! Careful with fingers and toes
She runs strong despite the rust in the tank, birds nest in the air cleaner, and no steering.
I’m getting lots of help as my stepson has dove in to get her back up to task. He’s pulled the wheels, replaced springs and brake shoes and has acquired a steering wheel, valve, and linkage. He’s cleaned the tank with muratic acid to rid the rust, then coated it with WD40. He’s also located the missing 3pt parts and some used tires and a wheel. He must miss working in fabrication at Vermeers. He has a game plan and seems to be doing great. At least I’ll be able to get the horse fence built while he fixes the hay mover. A6CA6C3B-4A9C-41E1-88A7-AA497B4C7D00.jpeg
   / 1841 coming back to life #4
WOW.. when you say "badly neglected" you weren't kidding.. Lol
It looks like a great project.. & with the type of HELP you've got.. it sure makes things easier..
Keep us posted & keep the pictures coming..
All the best.. TPG
   / 1841 coming back to life #5
If you can find some one parting out a HD 4000 and get the steering unit/column off that might save yourself a lot of headaches. Tony Jacobs might have some parts for the cable system if you need them but IMO the system stunk anyway. Better off changing it out. The one on my 1841 was replaced with a truck steering box. Good luck with your project.
Kirk
We’re making progress. 4 new tires, carb and fuel valve rebuilt, brake shoes and hardware replaced and steering valve column and wheel are together.
We are debating the tire fill if any. Been reading through old threads and I am leaning toward no fill and tubes. If the thorny locust cause too many problems then I’ll slime the tires. The right rear was to far coroded to save. So I’m very Leary about putting HCC back in them. A barrel weight on the 3pt and the wheel weights should be enough. �� I hope!
   / 1841 coming back to life #7
I think that most folks underestimate the benefit of loaded rear tires. All my Tractors are loaded and most have wheel weights on them. Maybe your part of the world is different and the extra weight won't make that much difference. I would love those Original weights that were on your tractor they are hard to come by these days and are usually expensive when they show up in our area
I can definitely appreciate the advantage of more weight, I’m just leary iwhen not if I puncture a tire with the HCC in them. Patching tires is a fact with those thorns and the filled tires make that a huge pain (draining, cleaning residue and the refilling the tires. I think a counter weight on the 3 pt will do about the same and not adversely effect tire repairs.
Progress. New steering and brakes.
According to my stepson she’s close. I’ll paint her once I get the paint booth built in the new shop. 4F12A1A0-61EC-4684-9B4E-108F0D850FAA.jpeg
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2022 JOHN DEERE 331G LOT NUMBER 96 (A53084)
2022 JOHN DEERE...
ALLISON TRANSMISSION (A53843)
ALLISON...
New Holland B95 Backhoe (A50490)
New Holland B95...
Hydraulic 80 mm pin thumb & coupler combo (A52384)
Hydraulic 80 mm...
2013 Great Dane 53ft T/A Reefer Trailer (A51692)
2013 Great Dane...
