1812 tearing up Starters ?
   / 1812 tearing up Starters ? #1
thetooth
North East
Kubota b7500 , Kubota Bx1850
I have a 1812 that is on the 2nd starter and it will soon be the 3rd if I can't figure out why it is chewing up the bendix gear .
I brought the mower out last week to get her ready for spring and when I cranked it over I heard a horrible grinding noise , the starter was engaged on the flywheel but the teeth on the gear were too worn down to spin the fly wheel .
So I ordered a rebuilt one from Amazon , installed it , mower started up fine the first time but the second time the starter stayed engaged and I heard the same grinding noise . I was able to get the bendix gear to retract , but it has hung up since then and is starting to wear down the gear on the new starter .
Any ideas why the gear is hanging up ? the battery and starter solenoid are both newer ( within the past year )
thanks
   / 1812 tearing up Starters ? #2
I do not know that machine , but it sounds like the starter is binding on the ring gear and should have a shim to hold it out a bit. Also the ring gear could be damaged by now and it will continue to eat gears untill the ring gear, and the Bendix, is changed and set properly.
Thanks I will try that , I also read that I should try lubricating the shaft .
1997 Caterpillar 950F Articulated Wheel Loader (A55973)
1997 Caterpillar...
PALLET OF CARBURETORS & PARTS WASHER (A58374)
PALLET OF...
2020 DRAGON ESP...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
CHANDLER 500 BBL FRAC TANK (A58214)
CHANDLER 500 BBL...
