180D warning lights
   / 180D warning lights #1
nepa
Forest City, PA
Mitsubishi 180D, Jinma 284 sold, Kubota BX2660, IH Cub, Case 580CK, Minneapolis Moline 4 Star (sold), TYM 574, Furukawa FX-040
My vintage 180D has 4 lights on the dash. The top 2 are green and for the turn signals. The bottom 2 are red warning lights, probably oil pressure and non-charging. Trouble is, they are not marked and my lower light is on. I can not find my owners manual. Can anyone help me? Thanks.
Thanks for the replies. I diagnosed the problem by starting the engine and pulling the wire off the oil pressure sender. The light went out. So the problem is either the sender or oil pump. Senders are about $15 and easy to replace. The pump $250. I guess that I will start with the sender.
By the way, I did find my manual. The dash pictured did not resemble the dash on my tractor and although it had lights it did not indicate which light was for oil pressure.
Heavy-Duty D-Ring Shackle Set (A53117)
Heavy-Duty D-Ring...
PALLET OF MILITARY STRAPS (A54757)
PALLET OF MILITARY...
UNUSED IRANCH 16" EXCAVATOR WOOD GRAPPLE (A54757)
UNUSED IRANCH 16"...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A54814)
2016 Ford F-550...
Ford 655C 2WD Cab Backhoe (A55218)
Ford 655C 2WD Cab...
2020 Club Car Onward HP Li ION Electric Cart. (A53424)
2020 Club Car...
