Backhoe 180 mini backhoe
   / 180 mini backhoe
One more picture from a front view showing the 1/4" plate sister welded to the OEM lift arms to beef them up.
   / 180 mini backhoe #12
Nice!! I always thought that my pt would handle a 12” bucket and with the info you have given us I will most likely go ahead and built it the 16 inch one. How about when you get a chance post a pick of it. Thanks for sharing the pics and the ideas.
   / 180 mini backhoe #13
Beechwood,
You are certainly "da man" and the bucket + thumb is "da bomb"
We should get you and stray together to have a "dueling MIGs" contest /forums/images/graemlins/grin.gif
   / 180 mini backhoe
Tracdoc.
I wish I could take credit for the welding but my knowlage of welding is "o".
I have a friend who is a welder by trade so I do carpentry work for him when he needs something built and vice-versa.
   / 180 mini backhoe
Stray
this picture shows the postion of the backhoe when it is mounted to the side rail of my trailer for transporting. Also a view of the 16" bucket
   / 180 mini backhoe #16
Very nice work indeed. Inspiration for the rest of us 180 owners. /forums/images/graemlins/smile.gif Thanks for the pictures.
   / 180 mini backhoe #17
Beautiful job. Looks like it just came out of a factory production.
Not sure if this applies or not, with the amount of stress my mini hoe puts on the center pivot pin with the small bucket, do you see any problem with the larger bucket?
PJ
   / 180 mini backhoe #18
Great job! What kind of control lever setup are you using for that added third hydraulic circuit?
   / 180 mini backhoe
Kent
The OEM 2 spool valve is a Sauer Danfoss . I bought the same configuration in a 3 spool valve from Sauer Danfoss.
I had to enlarge the mounting area and cut a larger hole in the side of the tunnel for the extra hoses. The old 2 spool valve will not go to waste, I'm planing on mounting it on the left side of the steering console for future use. I'll hook it up using the power beyond port from the three spool valve or vice-versa.
Just a note to any 180 owners. Do yourselves a favor and remove the lift arm hoses from behind the cylinder bracket.
I didn't notice the rubbing from the cylinder end until it was to late, /forums/images/graemlins/frown.gif
   / 180 mini backhoe #20
Cool!! Looks like two bolts and the buckets are swapped. Don’t go to any trouble but when the hoe is mounted to the trailer I’ll look forward to a pic of that. Thanks for this pic. Love that big bucket!!
MARATHON 76KW GENERATOR (A58214)
MARATHON 76KW...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2022 Club Car Tempo Golf Cart (A55853)
2022 Club Car...
(6) 2" X 3" UP TO 24' TUBING (A57192)
(6) 2" X 3" UP TO...
UNUSED 1RGC40 MINI GOLF CART (A57193)
UNUSED 1RGC40 MINI...
2020 Case 5550 Trident (A55315)
2020 Case 5550...
