17LA quick connects leaking-replace?
   / 17LA quick connects leaking-replace? #1
Scratchnbell
Fish Camp,California
New Holland 2001 TC40d
I have a set set of the quick connects that is leaking bad. Can it be "rebuilt" or are these things generic? Can I pick up a matching set at tractor supply? If so does any one know what specifically what these type quick connects are called and the thread size?
Thanks
Bob
   / 17LA quick connects leaking-replace? #2
On the NH parts lookup website, the quick-connect has the following description:
"Hydraulic, Female, 3/8" NPTF, O-Ring used is 122056 & Back-Up Ring used is 647327"
I think you probably don't need a new quick-connect but rather just the o-ring and maybe a backup ring. You should be able to buy these at your dealer or online at Messicks.com.
I don't know the generic size of the o-ring seal, only the NH part. If you remove your quick-connect and the o-ring, you might be able to match it.
I have a few of these O rings around the shop for a year or so. I bought them just in case. It took about 5 minutes with a tweezer and my pinky to get the old one out and them seat the new one.
THe main leak I was having was that the oring broke in half and a piece of it was wedged in the washer that closes it off and prevents the quick connect.
I truley didnt think that this little oring could hold all the pressure of the systen from leaking.
Bob
2012 Chevrolet Silverado 2500 HD Enclosed Service Truck (A52377)
2012 Chevrolet...
2015 Dodge Charger Sedan (A51694)
2015 Dodge Charger...
SHOP BUILT 96" X 25' TRI AXLE GOOSENECK TRAILER (A51247)
SHOP BUILT 96" X...
KMC 5610 (A53084)
KMC 5610 (A53084)
2012 VOLVO BL70B BACKHOE (A51246)
2012 VOLVO BL70B...
1262 (A50490)
1262 (A50490)
