17LA quick connects leaking-replace?
   / 17LA quick connects leaking-replace? #1
Scratchnbell
Fish Camp,California
New Holland 2001 TC40d
I have a set set of the quick connects that is leaking bad. Can it be "rebuilt" or are these things generic? Can I pick up a matching set at tractor supply? If so does any one know what specifically what these type quick connects are called and the thread size?
Bob
   / 17LA quick connects leaking-replace? #2
On the NH parts lookup website, the quick-connect has the following description:
"Hydraulic, Female, 3/8" NPTF, O-Ring used is 122056 & Back-Up Ring used is 647327"
I think you probably don't need a new quick-connect but rather just the o-ring and maybe a backup ring. You should be able to buy these at your dealer or online at Messicks.com.
I don't know the generic size of the o-ring seal, only the NH part. If you remove your quick-connect and the o-ring, you might be able to match it.
I have a few of these O rings around the shop for a year or so. I bought them just in case. It took about 5 minutes with a tweezer and my pinky to get the old one out and them seat the new one.
THe main leak I was having was that the oring broke in half and a piece of it was wedged in the washer that closes it off and prevents the quick connect.
I truley didnt think that this little oring could hold all the pressure of the systen from leaking.
Bob
2023 WESSEX RMX500 LOT NUMBER 44 (A53084)
2023 WESSEX RMX500...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51248)
(2) METAL SPOOLS...
2005 GENIE Z-45/25 TELESCOPIC MANLIFT (A51246)
2005 GENIE Z-45/25...
2015 CATERPILLAR 323FL EXCAVATOR (A51246)
2015 CATERPILLAR...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
(4) STEEL CARTS (A51248)
(4) STEEL CARTS...
