1739e DPF issues
   / 1739e DPF issues #1
Finley232
1739e
I have a 2016 1739e Massey. It has been a great tractor until lately. The DPF light started kicking on and staying on, then it would trigger the engine light. Recently it started beeping and cut to 1500 rpm's. This all started happening right at 500 hrs. I took it to the dealer and they said they needed to clear the code and there was a certain way to let it cycle thru the dpf cycle. After having it for 2 1/2 days I called to find out that apparently the code wouldn't clear and they have my tractor stripped down and working on things?!? So I will take that fight up with them, but has anyone else had DPF issues around the 500hr mark? Any DPF cycle issues?
   / 1739e DPF issues #2
Is there any chance you have a sensor issue on the tank itself?
Honestly I got no real life experience here so just speaking out of my butt.
   / 1739e DPF issues #4
Have you been replacing both fuel filters regularly - especially the little one on the bottom? If it plugs up it will melt the burner.
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A51039)
2016 KBH...
2021 ALLMAND BROS, INC. NIGHT LITE LIGHT TOWER (A50854)
2021 ALLMAND BROS...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51219)
2018 FREIGHTLINER...
PAIR OF TALL STACK PIPE RACKS (A50854)
PAIR OF TALL STACK...
2007 HYDRO-AX 764 MULCHING MACHINE (A51242)
2007 HYDRO-AX 764...
Mk Diamond MK-101 Wet Tile Saw (A49461)
Mk Diamond MK-101...
