1735m radio plug
   / 1735m radio plug #1
bken
1735m
I need to switch two wires on the radio plug. I was wondering if anybody knows how to pull the pins out?
   / 1735m radio plug #2
Look at the pins carefully. Many have a small latch which must be depressed. For plugs with flat pins a jeweler's screwdriver will frequently suffice. For round pins you may have to purchase a kind of tubular tool to fit around the pin and depress the latch. You'd better be really sure you want to swap wires around. Sometimes that can let the smoke out of some devices.
   / 1735m radio plug
When i turn the tractor off the radio time goes back to 1:00 and i always have to redo my bluetooth. The radio isn't getting 12 volt constant
   / 1735m radio plug #4
Massey actually makes them that way so they don't run down the battery, since typicaly they are not driven every day like a automobile.
2002 Blue Bird F131612 Bus (A51692)
2002 Blue Bird...
Wolverine Quick Attach Utility Hitch Adapter (A50514)
Wolverine Quick...
1998 Volvo VN T/A Dump Truck (A50323)
1998 Volvo VN T/A...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A52748)
2020 New Holland...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
