1725, put my hoe back on...
   / 1725, put my hoe back on... #1
Huntinguy
Demokratik Republik of Washington
Iseke TX1300
I took my hoe off for snow season and just put it back on.
Now while I am driving my hoe moves to the left... alli by itself.
Any thoughts as to why?
Pretty sure I hooked the hoses back correctly.
   / 1725, put my hoe back on... #2
Run it left and right a coupe of times to take air of the circuit and see if it still does it.
   / 1725, put my hoe back on... #3
Mine will often creep left (or right?) also. I think that's not unusual.
Okay,
I will wiggle it around and see what happens.
It is the first time that I have taken it off and put it back on.
Wasn't sure if I did it wrong.
Thanks
   / 1725, put my hoe back on... #5
Colored zip ties are wonderful for relocating hydraulic couplers in their correct positions. I use them on all my powered implements. Far as a BH is concerned. Never owned one and don't want to. If I need a hoe, I rent one. That way there is no maintenance and no hassles.
The Kubota dealership I work at part time, it seems that every new tractor owner wants one even though the owner tries to dissuade them. They buy it, use it a couple times and then it sits in the corner of their shed or outside tarped up and rusting away.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2023 Kubota KX057-5 Compact Excavator (A56436)
2023 Kubota...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2008 Ford F-450 Knapheide Service Truck (A55788)
2008 Ford F-450...
8 Piece Mini Excavator Heavy Duty Attachment Set (New/Unused) (A59225)
8 Piece Mini...
2014 Transcraft DTL 3000 53ft. 50 Ton Tri Axle Drop Deck Equipment Trailer (A55973)
2014 Transcraft...
