xtriggerman
- Joined
- Sep 6, 2018
- Messages
- 8
- Tractor
- Kubota B2150
So this tractor is up on a near by auction and I need to find out as much info on this issue as I can to see if I want to roll the dice on it. Here is all I know right now other than it runs perfectly in a vid in I'm guessing 2wd. So its likely the "front end locks up" is talking about the 4wd engaged front axle or transfer case issue? friday is inspection day so any inside hints on what to try or look at to isolate the issue would be a huge help. I dont mind doing gear work on the front axle but if its a split the tractor to yoke out the transfer case (non hydro) I think I'll pass on it. This old tractot is the ideal size I'v been keeping a look out for. No states hours in the info but starts right up with no smoke and the driver chirped the tires moving into 2nd. so the dry clutch should be tight.
- Runs & Operates
- Front End Locks Up
- Will Need New battery
- Tractor# G009686
- Engine# 57874
