1720 hyd capacity
   / 1720 hyd capacity #1
Anonymous Poster
Epic Contributor
I was curious what type of hyd (open, closed) hydraulic system a 1720 has, and it's capacity? Would it work for running an orbit motor on, say, an auger, etc. Or best left to more intermittent uses?
--->Paul
   / 1720 hyd capacity #2
I've used a 1720 with both a FEL and backhoe attached. With the backhoe, I actually had to set the engine at about 1500 rpm's, otherwise the hydraulics operated too fast. Don't think you'd have a problem with most hydraulic driven implements.
   / 1720 hyd capacity #3
It is open center, off the top of my head, I'll say it is about 7 or 8GPM. If you run an orbit motor, return the oil directly to the rear axle, not through a valve spool, unless you need to reverse the motor. This prevents shaft seal damage from pressure spikes in the return line when closing the valve. There is a plug on the hitch valve that can be removed providing a zero pressure return.
2008 Isuzu NPR-HD Landscape Dump Truck (A56858)
2008 Isuzu NPR-HD...
2016 SERCO 8500 KNUCKLEBOOM LOADER (A58018)
2016 SERCO 8500...
2017 Freightliner Derrick Digger (A55973)
2017 Freightliner...
2014 Ford F-150 4x4 Crew Cab Pickup Truck (A55973)
2014 Ford F-150...
CLAYS 6' X 10' S/A TRAILER (A52708)
CLAYS 6' X 10' S/A...
2014 Takeuchi TB290 Mini Excavator, S/N 1851007797, Diesel Engine, Tag 24" Bucket w/Thumb, 18" Wide (A59076)
2014 Takeuchi...
