1720 aux hyd?
   / 1720 aux hyd? #1
Anonymous Poster
Epic Contributor
I'm looking at a 1720 with a front end loader. Walking around it, I see there is no hyd port(s) on the back of it.
Can there be? Is that an option, or an add-on kit (spendy?)?
If the loader is removed, can the twin quick-couple ports for the loader be plumbed to the back with some hoses, & the joystick used to run hyd implements?
I have a farm background, but not real good with hydaulic systems...
--->Paul
   / 1720 aux hyd? #2
A rear hydralic port is a dealer added option on the 1720. I'm not sure the cost, but it has been in the $500 range for my Ford/ New Hollands.Andy
   / 1720 aux hyd? #3
Are you looking for a "controlled" rear hydro port or just one to hook up a backhoe or similar device. For a backhoe, I've seen where they just plumb it with hose from the hydro block, located on the right side of the tractor under/infront of the foot rest, back to the implement. Plumbing in this way would give you no control but provide a supply to a backhoe. If you want control, then the factory kit is a really nice way to go. It taps on to the valving under the seat and provides a control lever in the fender.
2020 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A58018)
2020 FREIGHTLINER...
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
LOT: (9) Sets of Gutter Broom, 250 KP, Std 26 (5 SEG) (A59076)
LOT: (9) Sets of...
2011 Ford Escape XLT SUV (A54815)
2011 Ford Escape...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A55973)
2019 Ford F-150...
