1720 Alternator wiring problem
   / 1720 Alternator wiring problem #1
jnhelton
new-holland 1720
Anyone have a color-coded wiring diagram for the alternator on a 1720? I discovered I don't have a warning light for the alternator. In my investigation it turns out that 2 wires in the wire bundle within inches of the alternator aren't terminated. A white red striped with brown spots wire that goes back to the light. A white with brown spots (no stripe) that goes to the "L" terminal on the Alternator.
If I connect these, the light works perfect but the tractor won't stop running with the ignition switch off. The reason is that the "L" wire carries a constant 2 volt current when the alternator is spinning. This voltage bleeds back to the fuel stop solenoid and is just enough to keep it from shutting off.
HELP! Thanks
   / 1720 Alternator wiring problem #2
HELP! Thanks
Closest thing I have is for 1710. I don't know how close it is to 1720. It just might give your some clue. please look at the attached PDF.
JC,
   / 1720 Alternator wiring problem #3
JC, it appears from your diagram that you have an external VR and the OP has a VR internally in his alternator from his description of the wires. Don't know. . .:confused:
Thanks to both of you. Didn't know this is the quick way to reply. Yes I have an internal VR. Can anyone say whether or not the 'L' terminal should be putting out the 2 volts constantly? Thanks
   / 1720 Alternator wiring problem #5
Jnhelton, I answered your PM. Without the diagram, I think there is an isolation diode missing, bypassed, or shorted. My tractor has an isolation diode to keep any postive voltage from feeding back and powering the bus through the light.
   / 1720 Alternator wiring problem #6
Yes Jim, You're right. I do have External VR on my 1700. The diagram I posted was for Ford 1710 rather than 1720. That was the closest thing I had on my IT FO-44. I thought it might help the OP some.
JC,
   / 1720 Alternator wiring problem #7
JC,
Well your diagram does show the light "L" lead from the external regulator. It's wired pretty much like mine and others with internal regulators, but I have an isolation diode after the light between it and the bus. I'm not sure of the symbology on your diagram, but I didn't see anything like that.
I'm betting you're right jinman. This isolation diode is in the internal IC circuit right? I think the original owner cut the wire rather than fix it!?
   / 1720 Alternator wiring problem #9
I think you could put one inline. Just make sure the negative end is turned toward the alternator's "L" output. That way it will allow normal current to illuminate the light and isolate the circuit when the key is turned off.
EDIT: I just changed the word above to "negative." I don't know what made me type positive the first time. Must be old age.:D
   / 1720 Alternator wiring problem #10
HELP! Thanks
There is a diode on that circuit, it is available through NH, PN SBA385620220
You and the jinman agree. But where do I physically put the diode. Between the two wires? Thanks
   / 1720 Alternator wiring problem #12
It should connect the W/R wires
   / 1720 Alternator wiring problem #13
You obviously know more details of the 1720 than I do, so I'll take a seat to the side and let you give what seems to be good and accurate advice. Thanks for chiming in and takin' up the slack.:thumbsup:
Finally got the diode! I live in a tiny little town in AR. Everything here comes from 22 miles away, mail or ponyexpress.
In terms of current flow which side of the circuit gets blocked (alt or gauge)?
I want to thank youall for the help.
I do have another question. Can overheating cause temporary blowby? Does overheating change the viscosity of oil? I guess thats two questions.....
Thanks again
   / 1720 Alternator wiring problem #15
Thanks again
Hook up the diode, and reconnect all wiring. Key on-engine off, the alternator light should be on. If not, reverse the wires to the diode.
Overheating could cause temporary blowby, if the rings stick in the pistons. Usually, a cylinder scuffs, that's permanent. Overheating can cook the oil, changing it in many ways. Fix the overheat issues, change the oil and filter, and hope for the best
Last entry on this thread. I recently bought this tractor. What precipitated the alternator question was that I blew a fan belt and found out I did'nt have an alt warning light or a working temp gauge. Well the light and gauge work properly now but it turns out that it was too late for the engine. Anyone have a recommendation for finding a rebuilt engine? Thanks again youall.
2452 (A60432)
2452 (A60432)
Sterling 9500 (A61306)
2017 Mercedes Benz GLA SUV (A56859)
2017 Mercedes Benz...
Informational Lot - Financing (A61306)
Informational Lot...
2014 Chevrolet Tahoe SUV (A59231)
2014 Chevrolet...
SKID STEER BUCKET (A58214)
SKID STEER BUCKET...
