1715 will not go into gear. clutch?
   / 1715 will not go into gear. clutch? #1
fishjett
Hey, I am a new member and first time tractor owner.
I have a 1995 ford 1715 W/ bucket .
I was pushing A manure pile with the bucket and the tractor and it stopped.
It feels like it's in between gears I put the clutch in and can shift gears
but when I let out the clutch It tries to go Into gear and skips and starts to roll a couple inches and stops. Is this a clutch out or somthing shifted inbetween gears?
Thanks,
Ron
   / 1715 will not go into gear. clutch? #2
Thanks,
Ron
I had a situation like that with my 1700. I have both gear shifter and range shifter. The shifter was stuck in between the two gears. There is a detent ball and spring theta keep the shifter solidly where it need to be. Any how I ended up loosening the shifter bracket to position the detent ball correctly. Does your shifter moves freely? does it stay in intended position without jumping?
JC,
Yes, the shifter moves freely and stays In position but when in gear You hear
grinding of and on trying to catch a gear.
Ron
   / 1715 will not go into gear. clutch? #4
Ron
Ron,
Does it grind when in gear and clutch pedal fully pushed in all the way? if so, then release fork may need to be adjusted closer to the fingers on the pressure plate allowing you to fully disengage engine to transmission input shift.
JC,
Thanks for your help jc. I am gonna work on it tonight.
Ron
2014 Ford Escape SUV (A51694)
2014 Ford Escape...
THOMPSON F4L 1011 PORTABLE DIESEL PUMP (A51406)
THOMPSON F4L 1011...
2016 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A53426)
2016 FREIGHTLINER...
ROME GK-14 LOT NUMBER 68 (A53084)
ROME GK-14 LOT...
UNUSED AGT YSRT14 STAND-ON SKID STEER (A51247)
UNUSED AGT YSRT14...
2019 KENWORTH T800 (A53843)
2019 KENWORTH T800...
