1715 clutch problems
   / 1715 clutch problems #1
jabies52
Jonesboro Louisiana
ford new holland 1715
I have a 1996 model 1715 Ford and the clutch seems to be slipping . I would like to find out how to adjust it.
   / 1715 clutch problems #2
there should be and L shaped rod pin in your clutch pedal you remove it and tighten it up on the other end an reconnect when done u should have 1.5 inches in free travel
I found the L shaped rod . The flat piece of metal it is connected too has two holes in it . The rod was connected too the back hole I put it in the front hole and now it seems to hook up fine. Is this alright?
   / 1715 clutch problems #4
If you had free play at the top of the pedal and the clutch slipped, then it will need a new clutch disk.
The clutch engaged at the top. When going up a step grade tractor would lose momentum with motor at steady rpm.Sence moving the rod too the second hole the clutch seems to be alright. Just wanting someone to tell me I did the right thing.
2012 International 4300 Reefer Truck (A53473)
2012 International...
2015 Ford Fusion S Sedan (A51694)
2015 Ford Fusion S...
Hand Truck (A52377)
Hand Truck (A52377)
Guard Rail Pieces (A51692)
Guard Rail Pieces...
UNUSED Woven Landscape Fabric (A53117)
UNUSED Woven...
John Deere (A50322)
John Deere (A50322)
