1710 running hot
   / 1710 running hot #11
If your engine temp is maxing out at 200 under load, I don't think you have a problem. You should, as a matter of routine, keep the radiator fins clean. Spraying a little detergent on the fins after wetting them seems to loosen the dirt better than water alone. Also, as a matter of course for PM, it wouldn't hurt to flush your radiator with one of a number of commercially available agents. If you indeed have a problem, I wouldn't expect that it's a very serious one.
Jim
   / 1710 running hot #12
I also have a 1710 ford that gets hot,ive changed waterpump,thermostat 180 checked radiator its not stopped up and i can see through it,changed cap to a 13 pound. i start it up runs fine temp normal but seems its always loosing antifreeze from over flow tube,just enough pressure for the antifreeze to run out.ive let it run with cap off circulates good,I figure its getting hot from the loss of coolant but really dont understand why it keeps loosing? cracked head?headgasket?no moisture on oil cap,no smoke,no miss?no fluid in crank case? had a 9 pound cap before i changed it
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
2002 FREIGHTLINER FLD 132 SLEEPER TRUCK (A58018)
2002 FREIGHTLINER...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
404 (A52706)
404 (A52706)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2007 50FT 3 CAR HAULER TRAILER (A58018)
2007 50FT 3 CAR...
