1710 4 wheel drive shifter issue
   / 1710 4 wheel drive shifter issue #1
couger94
Alden NY
Ford 1710
Hi everyone, I am a newbie to this site and to tractors in general. I bought a 1986 ford 1710 4x4 diesel. It has around 700 hours and a loader. It is in fantastic shape. The problem, I have only been able to shift it into 4 wheel drive once. I am pulling till my shoulder is about to pop out and it only has gone in once. Has anyone ever run into this problem and where should I start to diagnose it. I thought about removing the lever (plate on top of the tractor that it runs through) to see if there was a problem. I have tried to creep it and I am keeping the RPM's low. PLEASE HELP I am paranoid that I just threw my money in the fireplace.
Jim
   / 1710 4 wheel drive shifter issue #2
Jim
Jim,
You should not be forcing it as it might cause more problem. Look the PDF attachment below. Look at items 15,16,and 17 that make your shift fork mechanism. # 17 is your detent ball that keep the the 4wd from jumping out . Remove the cover slowly and carefully and check condition of the detent ball and spring. I bet ya that's where your problem lies. Ball out of round, broken spring and things like that. I had the same issue with my gear shifter that pretty much used the same mechanism. I do not 4wd on my 1700 though.
JC,
  • 1710- 4wd diagram.pdf
   / 1710 4 wheel drive shifter issue #3
Another solution might be to shift while rolling and clutch depressed. Make gear alignment easier.
Russell
Hi, thanks for the input. Jones I have tried that to no avail. JC I can't thank you enough but if I could ask another question and I again apologize if it is a dumb one. How willi know if it is the ball out of round or a bad fork? Is the fork viewable once the cover is off?
TORO MBTX 2500 STAND-ON CONCRETE BUGGY (A51406)
TORO MBTX 2500...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A53472)
Michelin CARGOXBIB...
UNUSEDX-STAR 72" QUICK ATTACH GRAVEL LEVELER (A51247)
UNUSEDX-STAR 72"...
UNUSED HURRICANE D6028 JOB BOX (A51248)
UNUSED HURRICANE...
2016 JOHN DEERE R4038 LOT IDENTIFIER 181 (A53084)
2016 JOHN DEERE...
