1700 starting issue
/ 1700 starting issue #1
kemack
The starter solenoid on my 1700 started spitting sparks a couple of weeks ago so I called my local New Holland Dealer and they shipped me a new imported solenoid. I installed the new solenoid by removing the cables and wires from the old solenoid and hooking them up the same way on the new solenoid. Everthing worked great and I was mowing again. Yesterday I stopped after a few hours of mowing, it will not start. Turn the key to the on position and the oil & battry lights come on strong. Turn the key to start, I hear a click and the lights go out. Turn the key back to on and no lights. Wait about an hour, turn key to on, battery & oil lights come on. Turn key to start, click again and lights go out. Tried disconnecting the wire from the ignition to the solenoid and then jumping from that terminal to the battery side of the solenoid, same thing, lights out & click. Pulled battery to put on charger and charger shows battery charged. While battery was out tried the battery from my Wrangler just in case, same result.
Any idea what is going on?
Thanks in advance.
Kemack
/ 1700 starting issue #2
I would think a bad ground connection. I had a similar problem with mine and the connections looked good. Turned out that there was corrosion where the cable was crimped onto the wire to the connector. I replaced the battery cable and have not had any more problems. Also disconnect the negative cable at the frame and make sure it is clean and free of corrosion.
I cleaned all the battery cable contact areas. She fired right up. I did not even think about corrosion. I'm back in the saddle again.
Thanks Sailor Bob for the great advice.
Kemack
2022 EZ-GO ELITE...
2018 CATERPILLAR 299D2 SKID STEER (A65053)
2018 CATERPILLAR...
2018 Ford Explorer AWD SUV (A64557)
2018 Ford Explorer...
Indian Totem Pole (A64557)
Indian Totem Pole...
2025 Kubota SVL75-3HFWCC High Flow Cab Track Loader - 70 hours
2025 Kubota...
TAYLOR LASTOVER HARVESTER (A64278)
TAYLOR LASTOVER...
