1700 glow plug / thermostart
   / 1700 glow plug / thermostart #1
fig
Thomasville, NC
yanmar 1700
Alright guys; forgive my ignorance and bare with me because I am "beating a dead horse" and not real familiar with diesel engines.
I guess I have some misconceptions about what a glow plug / thermostart system actually does. In a past post that I had (2000 to 1700 thermostart); one of the replies talked about the thermostart system actually burning fuel in the manifold. I also received some great information on where to find a possible replacement. I went to a Thermoking dealer/service center this afternoon and looked at their glow plugs and was told that the glow plug only heats the intake air. So now I am kinda cornfused.
Did earlier thermostart systems actually burn the fuel to heat the air in the intake and later versions just heat the air? I looked at one glow plug for a 2 cyl. yanmar and the end looks like a spiral coil and does not have an oriface for fuel to drip through. If I installed this type of glow plug; would it work the same as the thermostart system?
Sorry for the long post and thanks to everyone that responded in my other post.
   / 1700 glow plug / thermostart #2
Ah, confusion, glowplugs are not thermostart and vice versa. Most yanmars do not have glowplugs, but just rely on compression for ignition; however, thermostart actually starts a small fire in the intake manifold from igniting fuel dripping from the small bottle to aid in cold weather starting.
   / 1700 glow plug / thermostart #3
The thermostart plug is like a cigarette lighter element, for lack of better description. It is in the intake manifold. It gets hot and fuel drips on it and ignites. A glow plug which a 1700 or a 2000 does NOT have, and could be in the cylinder, heats the chamber "air" to help ignite the fuel as it's injected.
   / 1700 glow plug / thermostart #4
All thermostart systems for Yanmar burned fuel. I believe the newer F series Yanmars use glow plugs in the cylinders. What you are describing has also been used as a cold weather starting aid. An electric heater heats the fresh air as it passes by the heater. I don't believe Yanmar used this in any tractor applications.
The TS plugs at the Thermoking dealer/service center didn't have the hose fitting on the end for a fuel line? If not, they weren't TS plugs. I don't know how well an inlet manifold heater would work. It seems to me that a very large amount of heat is required, and that something the size of the TS plug wouldn't provide enough heat to do the job. But, I could be wrong.
I don't use the TS systems in my two Yanmars. I put block heaters in both of them. I plug it in about a half hour before I want to use the tractor, and it starts like its 70 deg out. I would definately recommend a block heater over the TS. My YM1301D has one that goes into the water jacket through a threaded hole on the right (exhaust) side of the engine block. I made a pipe with 3/4" NPT spud to go in the lower radiator hose on my YM1110D. I bought a 400 Watt heater from Advance Auto Parts which threads into the spud.
Greg
Thanks for the responce. You responded to me when I asked about a block heater. I would like to go that route, but I have no threaded ports on the exhaust side of the motor and I don't have enough clearence in the lower radiator hose to install a heater there either. I looked at several different heaters at NAPA, but I can not find anything that will work (hose heater, soft plug heater). Seems like everything I have looked at either won't work or not enough room to install. This is why I have gone to the thermostart. Maybe I can talk the wife into heating the barn (riiiiight)!
   / 1700 glow plug / thermostart #6
Try a magnetic block heater..
Soundguy
   / 1700 glow plug / thermostart #7
I put a tarp over my trator and put an oil filled elec heater under the tarp. Heats the engine compartment. works great. I just plug it in about an hour before I start the rig. easiest way to do it.
   / 1700 glow plug / thermostart #8
Fig,
I had the same problem with my YM1110D. No threaded holes, and only a single freeze plug - I was reluctant to use the ONLY freeze plug hole on the block for a heater. The lower radiator hose was so short and bent, that I couldn't find a heater that would go on. So I took a short piece of thin walled 1" pipe and cut a piece out of it. I then cut a 3/4" NPT coupling to weld to the 1" pipe at an angle. I then used a 400 Watt 3/4" NPT block heater from Advance Auto Parts. It threads into the 3/4 coupling, and the element goes up into the 1" pipe. I attached a photo of it installed on my YM1110D. I just finished making a second one for the YM1110D I sold recently.
Greg,
Thanks for the information and picture. I see what you were talking about now. The only reason why that would not work on mine is because the alternator is on that same side, so the fan belt runs around the lower radiator hose making for an even more confined space. If it was not for that, then the hose heater that I looked at at NAPA or one like yours would work. I have come to the conclusion that it is time to call Hoye to see if I can get the whole TS system. Thanks to all for the help.
Newton
   / 1700 glow plug / thermostart #10
It appears that Hoye has the system, (wouldn't you know, he calls it a glow-plug), but it's going to be pricey if you have to buy it piece by piece. My tractor is in N. Ga. and I have never used or needed my TS and am not sure how effective it really is. I believe I would go the tarp/heater route, (electric or kerosene), If I needed cold weather starting help and did not have TS.
2013 WABASH 53x102 DRY VAN (A53426)
2013 WABASH 53x102...
Case 580B Backhoe   (A52384)
Case 580B Backhoe...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/nerve-alive-supplement-reviews-inspired-by-nervecalm-for-natural-nerv-1044754
https://www.accessn...
2011 FORD FIESTA SE CAR (A51247)
2011 FORD FIESTA...
2006 Lexus ES 330 Sedan (A51694)
2006 Lexus ES 330...
2014 FREIGHTLINER 114SD VACUUM TRUCK (A51406)
2014 FREIGHTLINER...
