1700 Amp meter installation
   / 1700 Amp meter installation #1
drakefamily2
ford 1700
Any body ever install a amp meter in a 1700. If so where did you hook it into.
   / 1700 Amp meter installation #2
Needs to go between generator and battery.
   / 1700 Amp meter installation #3
If you want it to show discharges.
Find the main hot wire where it goes to the battery, run it to the gauge.
Then from the gauge back to Usually the solenoid switch.
If its backwards just swap on the gauge.
Then it shows discharge and what is going to the battery after the accessories.
Ds
Tractor has alternator. Not practical to install betwween alt. and bat. wire too large.
   / 1700 Amp meter installation #5
There really is not a good wat to put an amp meter on these tractors. If you put it between the alternator and the battery, you only see what the alternator is putting out. If you put it between the battery and the switch, you only see what the accessories are drawing.
I suggest adding a voltage meter. You can run a wire from the accessory side of the switch, and you can tell if you have a good battery and if it is charging properly based on the voltage.
If you have to have an amp meter, then you need to move the acc power from the back of the starter motor to the B+ on the alternator, then bput your amp meter between the alternaot and battery. That will change your power flow, and the meter will show true charge/discharge.
HF actually have some cheap ones i've used in the past, and i've never had an issue with them.
   / 1700 Amp meter installation #6
A volt meter is far easier.
Look at the sol switch, not the battery cable the other wires there on the big post.
DS
OK I 'll try a voltmeter.
   / 1700 Amp meter installation #8
Also, if you need to replace the alternator, I found that the following is a direct fit up. The output is higher, but fits right up.
Alternator from a 1974 Nissan 260Z
   / 1700 Amp meter installation #9
The 50 amp and the 35 amp came on lots of Datsuns and Nissans
Alternator just fine, replaced about 15 years ago. Will keep your info in mind, thanks
2010 Chevrolet Tahoe SUV (A50324)
2010 Chevrolet...
UNUSED HURRICANE F10 10' WROUGHT IRON SITE FENCE (A51248)
UNUSED HURRICANE...
1840 (A51248)
1840 (A51248)
City of Buckhannon Onan 200 Set Stand By Generator (A52384)
City of Buckhannon...
2010 Ford F-150 4x4 Pickup Truck (A51692)
2010 Ford F-150...
