17.5" Tires?
/ 17.5" Tires? #1
Harold_J
I've seen 17.5" tires/wheels available on some trailers in the 14-16K GVW range either as standard or an option. The option seems to add $900-$1000 to the price and I guess that might include a heavier axle, larger wheel studs, etc.. Would these be a good choice for a 16K gooseneck approx 20'+5' tail?
/ 17.5" Tires? #2
Never seen that size personally. I would look into how much it will cost in 5 years to replace that odd ball size tire.
Chris
/ 17.5" Tires? #3
17.5" is heavy duty stuff. My old 35 ton tandem low boy had 10.00x15 tube-type with 3-piece rims that I converted to 11R17.5 tubeless (demountable "Dayton" rims on dual spoke wheels). The 15" tires were no longer readily available and the 17.5" was the new standard. But that's about 10 years ago. Now I've retired to the smaller stuff.:)
/ 17.5" Tires? #4
In my former job, we used to put a lot of smaller single axle flatbed 5th wheel trailers on 215/75 R17.5 duals, and the medium tandem lowloaders on 205/65 R17.5 duals.
Availability was never an issue, as lots of distribution trucks used that size.
They had less rolling resistance, better puncture resistance and wear resistance than the lower 195/65 R16 we also used.
they might be more expensive but if you tend to wear tires before they get dry rot, they are definately cheaper in the end.
/ 17.5" Tires? #5
The 17.5 is a very common tire on low cab forward trucks everywhere but North America. The Nissan UD is the only one that uses it here on most except the 12,000 GVWR model which gets 215/85-16's
/ 17.5" Tires? #6
All distribution trucks of 6 to 12 ton i've been around, had 17.5 inch tires. Mostly 235/75 R17.5
That size is also popular for heavy duty lowbed machinery trailers. For the medium duty ones we built, we used 205/65R17.5 with axle loads up to 7400 kg.
The 235 tire is as cheap as the 205, because there are sold so many in Europe. The 235/75 R17.5 has totally replaced the old 15 inch heavy duty tires, mounted on 3 part rims.
/ 17.5" Tires?
One of the trailers I looked at had 215/75 R17.5 16 ply Load Range H.
These replaced 235/80 R16 LR E for almost $1000 more and included heaver wheels and 5/8" wheel studs on the axles.
/ 17.5" Tires? #8
These will be much more stable than the 16" pickup truck tires and last twice as long, never blow. IMHO worth the money.
/ 17.5" Tires? #9
Chris
Odd ball size? :confused:
I'm shocked our resident trailer expert has never seen them. Heavy duty trailers are commonly equipped with 17.5's. They are ridiculously heavy duty and last forever. The ones on my trailer are load range H !!
I have them on my Cam Superline :)
/ 17.5" Tires? #10
I'm shocked our resident trailer expert has never heard of them. Heavy duty trailers are commonly equipped with 17.5's. They are ridiculous heavy duty and last forever.
I have never seen them but that does not they are not out there. To be honest I have never seen anything but standard 8, 12, 13, 14, 15, and a few 16" rims and tires on trailers.
Chris
/ 17.5" Tires? #11
Back when I worked for a GM truck dealer most of the tires I saw on the W4 and W5's (just rebadged Isuzu NPR's) had 17.5" tires on them. Like LRH said, they are very common on low cab forward trucks.
/ 17.5" Tires? #12
17.5" tubeless tyres/tires replaced the old tube type 15" tyres on low loaders/lowboy's . The biggest reason for the change was to create a bigger air gap between the brake drum and the rim . Red hot brake drums , 3/4" away from the tube was causing blowouts . Now there is a good air gap on the same axle/brake drum setup . Going tubeless also had obvious benefits .
/ 17.5" Tires? #13
Back when I worked for a GM truck dealer most of the tires I saw on the W4 and W5's (just rebadged Isuzu NPR's) had 17.5" tires on them. Like LRH said, they are very common on low cab forward trucks.[/QUOTE
That must have been a few years ago; as now they jump from the 16" directly to the 19.5". I have seen a few older ones with the 17.5's, and see references for wheels occasionally. Must have scared some folks, so the US spec model Isuzu's (Japan built Diesels and US assembled 5.7/6.0 gasoline) no longer show them as standard, nor as an RPO. A local junkyard has an old wrecker chassis (GMC W4 or W5) with the 17.5,s. I have also noticed that UPS has used/specified them on some chassis. Nissan UD still spec's them for US.
/ 17.5" Tires? #14
Chris
Those are lightweight trailer tire & rim sizes.
Usually when a ".5" like a 14.5", 17.5" or 19.5" trailer tire size is designated, it means serious use and heavy duty.
http://www.econolinetrailers.com/Tilt-Trailers.asp
/ 17.5" Tires? #15
Econoline Trailers - Tilt Trailers - Utility Trailers - Equipment Trailers - Gooseneck Trailers - Flatbed Trailers - Industrial Trailers - Hydraulic Trailers - Dual Tandem Trailers - Trailer Parts - Trailer Sales and more.
Learn something new everyday. All I ever deal with is boats and utility/dump trailers with 3.5K, 6.0K, and 7.0K axles. Just curious, what is the GVWR of that trailer you have and is it singles or dually? I am guessing you use it to haul you Case BH and if its like my neighbors I think it weighs about 16,000#.
Chris
/ 17.5" Tires? #16
My house/fifthwheel has Goodyear G114 215/75XR17.5 H, max load is 4805 @ 125psi. They seem to be good tires, they will dry rot before I will ever wear them out.
2016 Ram 4500 Wrecker/Snatch Truck, VIN # 3C7WRKAL4GG243467 (A61165)
2016 Ram 4500...
DRAGON 500 BBL FRAC TANK (A58214)
DRAGON 500 BBL...
2022 CATERPILLAR 262D3 SKID STEER (A62129)
2022 CATERPILLAR...
1999 Sterling L9513 Tri-Axle Roll Off Truck (A61568)
1999 Sterling...
2018 Freightliner Thor Venetian 400XCR A40 41ft. Class A Motorhome (A61569)
2018 Freightliner...
500 BBL WHEELED FRAC TANK (A58214)
500 BBL WHEELED...
