16la loader float?
   / 16la loader float? #1
cperky
Middle TN
John Deere 1025r with 120r front end loader, Hustler zero turn mower
Does my 16la loader have a float feature as I have read some others do? If so how do activate the float?
Thanks,
Chris
   / 16la loader float? #2
Yes, it does. Push your joystick all the way forward as far as it will go. It will not only go into float, but the joystick should stay there in an indent. The curl circuit does not have float, but the raise/lower function does.
Thanks Jinman! I will give it a try
Chris
Well, I got a chance to try it out and....Exactly as you described! Cool! didnt realize I even had this feature. Thanks again
Chris
   / 16la loader float? #5
Chris
U were lucky. I just bought a used TC40DA and my stick does NOT stay in the forward position. As I already have a TC33D and it does stick in the float position, I guess I have to buy some new parts for the 40? I seem to remember replacing one of the valves in a JD I used to won. Is this an easy fix? Thanks, MB
   / 16la loader float? #6
When you push the joystick all the way forward, can you feel any indent at all? Does it have a slight "over-center" feel as you approach full forward? IF so, it might be that the rubber boot has enough spring to it that it is pushing the joystick out of indent. You do have a 16LA loader and the rabbit/turtle joystick don't you? The new loader and it's joystick valve might operate differently.
I would pop the rubber boot out and see if the joystick stays in the forward indent when it is removed. It's just a guess, but the only thing I can come up with that could cause this problem.
BUSH HOG 2820 LOT NUMBER 125 (A53084)
BUSH HOG 2820 LOT...
2007 Anderson 25ft T/A Flatbed Equipment Trailer (A51692)
2007 Anderson 25ft...
2015 Top Hat T/A 20 ft. Gooseneck Trailer (A53117)
2015 Top Hat T/A...
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
2014 Mack CXU613 T/A Wet Kit Day Cab Truck Tractor (A51692)
2014 Mack CXU613...
2014 GMC Sierra Pickup Truck (A50323)
2014 GMC Sierra...
