16LA Lift Problem
   / 16LA Lift Problem #1
markey02
Traverse City Michigan
2001 New Holland TC40D
The 16LA FEL on my TC40D was working just fine last week. Now it will only lift about the height of the tractor hood. It does not matter if there is a load in the bucket and there is nothing blocking the FEL arms. Has anyone heard of or know what the problem is? Any suggestions or help would be appreciated.
   / 16LA Lift Problem #2
My dealer always says to check the fluid levels and quick connects if there are no other obvious obstructions. Even if you haven't disconnected the hoses recently, sometimes they aren't seated all the way the first time and with the movement of the loader they pull loose. Maybe try disconnecting all the quick connects, make sure they are clean, and reconnect making sure they snap in place nice and tight. Hope this helps.
Brad
   / 16LA Lift Problem #3
Mark, Brad's answer is exactly what I would tell you. It happened to me and I was devastated because I thought something had broken in one of my hydraulic lift cylinders. Just remove and reseat all your quick connect fittings going to your loader. If you look closely at them, you can probably see which one is loose. You'll be back to work with a smile on your face very quickly. /forums/images/graemlins/cool.gif
   / 16LA Lift Problem
Thanks jinman & SacandagaBrad!
I was going to check everything (fluid levels and connections) once I had a few minutes. One of the quick connect fittings was the problem. Cleaned them all, disconnected and re-connected and working just fine.
Thanks again!
   / 16LA Lift Problem #5
</font><font color="blue" class="small">( One of the quick connect fittings was the problem. Cleaned them all, disconnected and re-connected and working just fine. )</font>
Glad you got it working. I need to look at mine, but I can't get my hands in there to disconnect the quick connects for inspection. I suppose I'll have to make a special tool to get in there, or remove the hold down clamps.
   / 16LA Lift Problem #6
The best way to check the connections is to drop the kickstand, pull the pins, and back out a foot or two.
Mark
   / 16LA Lift Problem #7
Have_blue, I'm the original "fat-fingered freak," but I have plenty of space to get my hands in and connect/disconnect quick disconnects. Maybe if you raise the hood you can get a little more room. /forums/images/graemlins/confused.gif
   / 16LA Lift Problem #8
</font><font color="blue" class="small">( The best way to check the connections is to drop the kickstand, pull the pins, and back out a foot or two.
Mark )</font>
Great idea! Naaaah... I better not. I'm afraid I'd be tempted to not put it back on. /forums/images/graemlins/wink.gif
   / 16LA Lift Problem #9
I don't get it. I have a 16LA on my TC35D and I can check all the hose connections without any clearance problems. Us the TC40 that much tighter a fit for the loader?
   / 16LA Lift Problem #10
It is much easier to check the quick connects on the TC-40 by dropping the FEL and backing away from it. The clearance is pretty tight against the side of the cowling. Never had one act up yet but I am glad that I learned about the problem and the cure before that time.
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A52748)
2017 KINZE...
Hunter TCX53 Tire Changer (A50121)
Hunter TCX53 Tire...
2014 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A50323)
2014 GMC Sierra...
2019 Chevrolet Tahoe SUV (A50324)
2019 Chevrolet...
Kivel Q.A Pallet Forks (A50121)
Kivel Q.A Pallet...
TRUCKING INFO (A50774)
