Loader 16LA curl hose spec?
   / 16LA curl hose spec? #1
TC 40 Chuck
NW PA
NH TC40A
So, I blew a hose & thought that'd drive 2 mi to TSC instead of 30 to CNH dealer.
Put a freshly made hose on the tee fitting to curl cylinder and still leaks (a VERY small leak, but a leak...). Does anyone know the specs for the angle on the tee fitting? Is it "standard" like a "generic" fitting that I'd get from TSC crimped on the hose? OR - is it "different"?
Thanks in advance!:confused:
   / 16LA curl hose spec? #3
FWIW - The curl hoses, especially, can see significantly above system relief pressure with various work loads when the curl spool is centered. Iv gone to 4kpsi hoses in that circuit after failure of the original hoses. The uncurl/dump side is much less pressure stressed.
larry
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A55853)
2004 Pierce Tilt...
Adams 6T Fertilizer Spreader (A56435)
Adams 6T...
2005 International 5900i T/A Flammable Liquid Transport Truck (A55973)
2005 International...
New/Unused 72inch Quick Attach Vibratory Roller (A57454)
New/Unused 72inch...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2007 Ford F-350 9ft. Stakebody Flatbed Truck (A55852)
2007 Ford F-350...
