Loader 16LA curl hose spec?
   / 16LA curl hose spec? #1
TC 40 Chuck
NW PA
NH TC40A
So, I blew a hose & thought that'd drive 2 mi to TSC instead of 30 to CNH dealer.
Put a freshly made hose on the tee fitting to curl cylinder and still leaks (a VERY small leak, but a leak...). Does anyone know the specs for the angle on the tee fitting? Is it "standard" like a "generic" fitting that I'd get from TSC crimped on the hose? OR - is it "different"?
Thanks in advance!:confused:
   / 16LA curl hose spec? #3
FWIW - The curl hoses, especially, can see significantly above system relief pressure with various work loads when the curl spool is centered. Iv gone to 4kpsi hoses in that circuit after failure of the original hoses. The uncurl/dump side is much less pressure stressed.
larry
2014 Ford F-150 Pickup Truck, VIN # 1FTFX1CT2EFB75727 (A48836)
2014 Ford F-150...
2013 VOLVO VNM DAY CAB (A51222)
2013 VOLVO VNM DAY...
2009 L3 GENERATOR SET (A51222)
2009 L3 GENERATOR...
TOYOTA 42-6FGCU25 LP SIT DOWN FORKLIFT (A50854)
TOYOTA 42-6FGCU25...
2007 Hyundai Santa Fe SUV (A49461)
2007 Hyundai Santa...
12in Backhoe Bucket (A51039)
12in Backhoe...
