169d clutch and hours guage
   / 169d clutch and hours guage #1
yanmar169
Yanmar169
This is embarrassing, but I've got myself in a bit of a pickle and need help. I recently bought my first tractor, a 169d, that was "garaged" and showed 105 hours. It came with chipper, blade and brushed. I transported it to another state where I'm doing some work. The clutch seemed pretty jerky when I was loading, but the owner just said that was normal for these tractors and to feather it a bit. I put 12 hours running at 2000 rpm and the hours guage only turned 2? I had a lot of forward/reverse in the work I was doing and had headphones on. I eventually heard a squeal when clutch was engaged. The shift became sticker. I looked for a manual to see if i could adjust the clutch with no luck. I had a time constraints on the work I was doing and kept going. I grew up driving stick and so should have recognized the issue earlier. Now the engine drive doesn't consistently disengage with clutch pedal depressed fully. Where can I find parts, a manual and someone to replace a clutch on this model? Does anyone have suggestions on how to load it to get there? Any other suggestions? Thanks
   / 169d clutch and hours guage #3
Welcome to TBN!
Where are you located, and I guess, where's the tractor?
You might have a look for manuals over at the Yanmar Tractor Group. (@bmaverick)
All the best, Peter
   / 169d clutch and hours guage #4
- Manuals are on the YTOG, link in my signature.
- Clutch is popular for the YM169. The YTOG has you covered with SEVERAL listings for parts suppliers.
- A Harbor Freight Badland 2500-lbs 12VDC electric winch is able to pull the tractor up on the trailer if in neutral.
How to replace the clutch. Thanks to @AaronM for his detailed video. This is one of the most viewed for our machines and very often referenced. (y):love:
Bush Hog PT 15' Batwing Mower (A53317)
Bush Hog PT 15'...
John Deere 2640 2WD Tractor with 146 Front Loader (A57024)
John Deere 2640...
1000 Gallon Fuel Tank (A56469)
1000 Gallon Fuel...
2014 Dodge Avenger Sedan (A56859)
2014 Dodge Avenger...
(APPROX.128) UNUSED 1X6 TONGUE & GROOVE (A57192)
(APPROX.128)...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2008 INTERNATIONAL...
