165 Diesel alternator wiring?
   / 165 Diesel alternator wiring? #1
DLinMI
Decatur, MI
MF-165
I have a 165 diesel that had been converted to an alternator prior to my purchase. It has a GM 3 wire alternator with a built in regulator. I've tested it at the large post and it is working but must not be wired properly because the battery runs down. The only gauge that appears to work is the temp gauge and tach. It has a two wire push button ignition switch. Anybody help me wire this to charge the system? I'm open to replacing the oil pressure and ammeter, or should I install a voltmeter? I've searched and searched but can't find my identical situation. From what I've seen the wiring is different ammeter vs voltmeter and gas vs diesel and wiring the "exciter" wire. HELP! Thanks
Also, How does the ammeter come out of the dash?
   / 165 Diesel alternator wiring? #3
A voltmeter is more useful, it just sits in a rubber housing and can be pulled out.
   / 165 Diesel alternator wiring? #4
If you do not have the third "exciting" wire run through a warning light such as the schematic above, you will get a residual drain on the battery. This warning light acts as a diode switch to excite the alternator, but when shut off does not let voltage flow in the opposite direction. If this is the case, you could install a diode in the exciting wire to cure this. I bought a ten pk of 1000V -1Amp diodes on Ebay for not much money. This cured my problem with a hacked up harness.
2015 John Deere 544K Articulated Wheel Loader (A52377)
2015 John Deere...
2014 Chevrolet Tahoe SUV (A52377)
2014 Chevrolet...
2007 CATERPILLAR D5GXL CRAWLER DOZER (A51406)
2007 CATERPILLAR...
2017 Kubota M5-111D 105HP Agricultural Tractor (A52377)
2017 Kubota...
2023 KAUFMAN MINI V CAR HAULER TRAILER (A54607)
2023 KAUFMAN MINI...
197711 (A51244)
197711 (A51244)
