Loader 1640 FEL; Need a pic to fabricate repair
   / 1640 FEL; Need a pic to fabricate repair #1
shmaren123
Coventry, CT
JD 445, Kubota B7200
Hi all, Anyone out there have a 1640 FEL and could take a few pics of a discontinued part for me. (would be easiest if your FEL is off the tractor for what I need to see).
It's the left hand side sub frame assembly upright piece, its part number 70050-02557 Wedge, LH Upright.
I bought an older B7200 awhile back didn't realize on the left side, in the "pocket" on the tractor that receives the wedge it was completely rusted, musta been hanging on by a thread for awhile.
I was originally relieved to see I could order a replacement part for only $129 but sadly it was not in stock anywhere and I was told it was discontinued. I poked around on a few salvage sites and determined i would need to fabricate a repair. Fortunately the right side isn't nearly as rusted however, the bolts are giving me trouble on that side and I can't easily get it off to get a good look at what the bottom of this part is supposed to look like.
I've made a template fitting into the pocket and I have a crappy diagram from parts manual but looking at the right side and the drawing I see it looks reinforced on corners or sorta sitting on a "cradle" of plate steel I assume because this is a sliding surface. I would like to get a better idea of what this looks like. Any help would be appreciated.
I've attached a pic of my rusted part and the crummy drawing (the part I need to repair is labeled #1) IMG_1136.JPGIMG_1139.PNG
Thanks in advance.
   / 1640 FEL; Need a pic to fabricate repair #2
Hi shmarem 123. Do you still need pictures of the 1640 gel? There is no date on this thread.
   / 1640 FEL; Need a pic to fabricate repair #3
Date clearly shows as 09/04/2017......13 days ago!
   / 1640 FEL; Need a pic to fabricate repair #4
   / 1640 FEL; Need a pic to fabricate repair #5
Hello, still need pics? I have a 1640A loader
bad boy zero turn 72 (A56859)
bad boy zero turn...
2014 Ford Taurus AWD Sedan (A56859)
2014 Ford Taurus...
2012 Ford F-750 Pak-Mor 16 Yard Rear Loader Garbage Truck (A56858)
2012 Ford F-750...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
(INOP) 2016 FORD F150 XL SINGLE CAB TRUCK (A51406)
(INOP) 2016 FORD...
2007 Ford F-450 Ambulance (A55788)
2007 Ford F-450...
