1620 won't start when warm
   / 1620 won't start when warm #1
jodamax
new to me, starts somewhat hard, after it warms up and you idle it down to fast it dies will not start till it cools down. 446 hours on it anyone got any thoughts thanks
   / 1620 won't start when warm #2
THATS usually an indication of water in the fuel or poor QUALITY of fuel{Bio}
It slows the reaction of the pumps control rack & the governor cant compensate..
TRY removing the solenoid screwed into the block, just to the left of the inj. pump..
Get a small long screwdriver & push on the pumps control rack..{where the sol. was} it should immediately spring back..
I'll bet its SLOW..
IF your going to get the pump done.. do the injectors also..
   / 1620 won't start when warm #4
When you say it will not start, can you explain what you mean... Does it crank but not turn over, or does it not want to crank?
it will crank over forever but won't start tried glow plug or no glow plug just won't start till it cools down
   / 1620 won't start when warm #6
You need to start by cracking the lines at the injectors and see if you are getting fuel to the injectors. After that you need to figure out either why you are not getting fuel, or the next step would probably a compression test.
Seems like low hrs for low compression. I would start with the fuel flow to the injection pump, then check the injectors.
   / 1620 won't start when warm #7
He needs to start with a clean fuel tank, clean fuel lines, a new fuel filter and fresh fuel. Simple stuff first. Takes next to no time to pull the fuel tank. Wash it out well and start over.
   / 1620 won't start when warm #8
Also check your fuel cap... Might be pulling air into the system.
thanks everybody i'll try the simple stuff first
   / 1620 won't start when warm #10
Fuel cap?? The cap is SUPPOSED TO BE vented.. Its supposed to allow air into the tank..
U could try loosening the cap but that's prob. not your problem from the description..
2020 Kubota Z723KH 48in. Zero Turn Commercial Mower (A50322)
2020 Kubota Z723KH...
Super Material Lift MH1000 (A52748)
Super Material...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
2016 Laymor SM300 Towable Ride-On Rotating Sweeper (A50322)
2016 Laymor SM300...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
Vermeer 554XL Round Baler (A50774)
Vermeer 554XL...
