1620 cub cadet won't fire
   / 1620 cub cadet won't fire #1
docrocky
NW Ohio and SE Michigan
Oliver 880, Ford 8N, Ford 9N, Farmall Super C, MF 205, Ford 4400 FEL, Ford 4500 FEL/BH, Cat D-6 Dozer(1957)
Kept in barn all winter and started it up every 2 months and she purred. Today turned on ignition and it turns over but no ignition. Usually the lower light panel atop the steering column will show any problem, usually the center one of the lower 3. Even gave the battery a boost and still no fire, even ether to the carb. Where do I begin?
Thanks
   / 1620 cub cadet won't fire #2
I'm not familiar with the 1620 but I would start by removing the plug wires from the spark plugs, insert a screwdriver in the plug boot and hold it 1/8 inch from the engine block while cranking the engine You should see a spark jump to the engine from each wire as you test it. If there is a spark and it wouldn't start with the ether it may be a compression or timing problem. If there is no spark then the ignition module (coil) could be bad or is not getting 2 volts to it.
Bob B.
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2016 CATERPILLAR 304E2 EXCAVATOR (A52709)
2016 CATERPILLAR...
2015 Freightliner Bucket Truck (A55973)
2015 Freightliner...
2021 Fleco DX140 24in Tooth Bucket Excavator Attachment (A55973)
2021 Fleco DX140...
2025 14ft. Deer Motif Bi-Parting Driveway Gate (A55853)
2025 14ft. Deer...
2020 KENWORTH  T800 KILL TRUCK (A58214)
2020 KENWORTH...
