1610D broken breather tube on rear case
   / 1610D broken breather tube on rear case #1
evofxdwg
middle GA USA
Yanmar 1610D
1610D - small tube on top of left rear axle casing broke off flush. Is this pressed in or threaded? I assume it is pressed but need to make sure before i thread the stub and try and pull it with a screw. If that is not the best method, what is suggested to remove it?
   / 1610D broken breather tube on rear case #2
On my YM240 the big one on top of the differential housing was threaded. The flush fragment came out easily with an ez-out. Hopefully the little brake-housing vent is similar, if that's what this is.
   / 1610D broken breather tube on rear case #3
Thinking that is 1/8"BPT, I think this would work. Yanmar Tractor Parts: AIR BREATHER I tapped my vent hole on the hydraulic unit on my 2002d with a 1/8"npt tap and screwed a nipple in.
In any event, pretty sure it is threaded.
   / 1610D broken breather tube on rear case #4
If your talking about the small vent tubes for the brakes. On my 3110 they are threaded . The large 1 on top rear (center on my 3110) for the hydraulics is also threaded
Thanks guys.
Yes, the tube is on the brake housing assembly.
I dug out my Japanese parts manual and thumbed though it for an hour, went out and compared it to my tractor, and..................dang!........my parts manual looks like it is missing the page with the brake housing assembly!
If anybody has the YM1610D parts manual page marked at lower right with "N005417", i need a copy.
   / 1610D broken breather tube on rear case #6
You can't go wrong by assuming it to be threaded.
   / 1610D broken breather tube on rear case #7
And almost 99.9% sure there not Reversed. :D
I soaked in PB blaster and, with some effort to break it loose, backed it out with an ez out. It was threaded. Will see if Hoye has it. They have two different PN's for "breather" with no pix that could be it.
   / 1610D broken breather tube on rear case #10
003.JPGThat PN matches mine and is very common on alot of models.
NEW Wolverine 72'' Skid Steer Sickle Bar Mower (A53002)
NEW Wolverine 72''...
2009 Caterpillar 279C High Flow Compact Track Loader Skid Steer (A51691)
2009 Caterpillar...
2010 Chevrolet Tahoe SUV (A52377)
2010 Chevrolet...
1999 Volvo VN Truck, VIN # 4VA7BBJF9XN770848 (A51572)
1999 Volvo VN...
1994 Toyota 6000lbs 2 Stage Forklift (A53472)
1994 Toyota...
2023 JOHN DEERE 8R340 LOT NUMBER 221 (A53084)
2023 JOHN DEERE...
