1610 idiot light diagrams
   / 1610 idiot light diagrams #1
schalfback
When I turn the ignition key on, the upper right light goes on.I think that is my oil lite.?? Please some one tell me I got it right...upper left-battery upper right oil-bottom right amps bottom left radiator?? The only light that goes on is the upper right should the amp lite go on initially too.
Also my temp gauge does not work where is it located and where can I get a unit.
thank you....Al
   / 1610 idiot light diagrams #2
You could pull the wire off of the oil pressure sender and then you would know if that light is for oil pressure.
   / 1610 idiot light diagrams #3
Schalfback I've got a 1610D, I'll look at it tomorrow and let you know about those idiot lights.Look around the water pump for that sending unit to the temp guage,check to make sure the wire isn't broke or a loose connection.My idiot light used to come on at low rpms ,a new fan belt cured my problem. russ
2012 Hyundai Elantra Sedan (A50324)
2012 Hyundai...
43018 (A51691)
43018 (A51691)
Husky Tandem Tank Spreader (A50774)
Husky Tandem Tank...
2013 Ford F-550 Altec AT40G 40FT Bucket Truck (A50323)
2013 Ford F-550...
John Deere 650 Tractor (RUNS) (A50774)
John Deere 650...
