Here is what I have done (successfully) Two 2x12 pressure treated spruce planks layered with 3/4 " 5-ply fir plywood between them and. pre-stressed with a 2" crown facing UP and glued with Yellow Waterproof Resin glue from LePage, then NAILED, not bolted, on a close diamond pattern, with spiral zinc-coated 3 1/2 nails on a 16 foot span, resting on top of 4x4 PT square posts, with 1/4" thick mild steel cheek pieces bolted through the posts and then trough the beams above the posts against twisting. This header supports the outboard ends of my 2x4 "W" roof trusses 18" in from the eave. The trusses are 24" apart OC The roof is Steel on a 5 pitch slope. Snow load here maxes out at 50 Lbs per square foot, but the snow usually slides off several times per winter and hits the ground 12 feet below with a great thundering impact that makes the ground shake. I think that snow must weigh in at 12 tons or more. That laminated beam is a heck of a lot stronger that it looks, apparently, but I think it needs to be protected from the weather, hence the aluminum sheathing, plus I hate painting the trim on a ladder.
I am not an engineer. If I was, I would probably have specified a steel I beam. The carpenter disagreed with steel beams resting on wooden posts, because long steel beams have issues with thermal expansion, making the post and beam joint questionable over time. FWIW, he may have a point there. A 16-foot steel beam will expand and contract 5" over its length, he said. He made me a believer.
The devil is in the details,,and how you select and match up the planks, plus the glue and the nailing pattern.. WITH ARDOX nails. As you know they cannot be pulled out, even with a big wrecking bar.
The best argument is cost. The laminated beam cost 50 bucks for materials.. a 16'x 5" Mild steel I beam would cost about 800 bucks, from a scrap yard, if you could find one...and steel will bend and deflect over such a span anyways.
I have seen no deflection from tremendous roof snow weight for over ten years now, nor twisting torsion. I did choose the planks very carefully to be free of knots and adverse grain and arranged them with the assembly of the wood crowning up, and so that the opposing grain of the planks were not running coincidently parallel to one another and free of sap wood. I also ensured that the ends of the laminated beams were absolutely squared to the ends of the supporting posts so that there was no torsion introduced at the point where the beams rested on the posts. I drilled long 1/4 inch diameter holes at about a 30 degree angle to the vertical plane and placed 18" long galvanized lag screws into the the posts and beam ends inboard of the cheek pieces as a hedge against slipping of the beams off of the 4x4 PT support posts. The support posts are also sheathed with PVC siding clamshells.
The whole structure looks pleasing, too There are no interposing support posts to interfere with the view from my porch. Just how it should be.
This was done for me by a licensed carpenter. He said that the beam would support a ten-ton total span weight. He was correct, the beam is solid even with a snow load of three feet of frozen ice and snow on the roof at the eave.
I boxed-sheathed the laminated beam against the weather with aluminum metal..all in one length..and the metal sheathing does not deflect under the worst load. That beam is stronger than the headers for the stud wall beyond it, (doubled 2x6 on edge) supported on 16" centers by the stud wall.
